crx speedometer
Old Jan 30, 2006 | 05:23 AM
kantfadedisazn's Avatar
Default crx speedometer
just wondering i hav a 90 crx hf speedometer that reads up to 8000 rpm, i want to put i t in my 88crx hf, all the pulgs bolt up but is there anything else i need to do or buy to get it working properly
Old Jan 30, 2006 | 07:12 AM
wood's Avatar
Default Re: crx speedometer (kantfadedisazn)
you will have to swap the metal brackets that mount the cluster to the dash and use the cluster housing from the 90. The cluster shape changed in 1990 and so did the wiring. The swap can be done but it isn't plug and play
Old Jan 30, 2006 | 11:31 AM
Default Re: crx speedometer (wood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wood &raquo;</TD></TR><TR><TD CLASS="quote">you will have to swap the metal brackets that mount the cluster to the dash and use the cluster housing from the 90. The cluster shape changed in 1990 and so did the wiring. The swap can be done but it isn't plug and play</TD></TR></TABLE>
dam but all the plugs went in besides the hazard light
Old Jan 30, 2006 | 06:33 PM
wood's Avatar
They may go in but the wiring is different. Also the auto dim and hazard lights in the cluster are different.
Old Jan 31, 2006 | 12:28 PM
dam so i cant us it at all huh with out modifying it
CRX91SE
Feb 15, 2008 12:18 AM
Bright Eyes
May 28, 2005 05:26 PM
Kataku2K3
Mar 9, 2004 01:03 PM
iNetForce
25
Feb 20, 2004 08:59 PM
swtcivic93
Mar 1, 2002 09:56 AM
