ticking after valve adjustment
Old Mar 24, 2002 | 02:37 AM
S13 slide's Avatar
Default ticking after valve adjustment
hello, last night i did a valve adjustment on my cusins 93 ls, it has 140k on it and was ticking so we assumed that is the valves. but after the adjustment it sounds the same, still ticking. i dont have a helms for a b18a, but i do for a b18b, and i used those specs, and i set em at the tightest, 8 on intake and 16 on exhaust. are the specs for a 93 motor and 95 the same? or do they need diffrant clearances? thanks
Old Mar 24, 2002 | 10:52 AM
Nighthawk GS-R's Avatar
New User
Default Re: ticking after valve adjustment (S13 slide)
my guess it would be different. i think the 90-93 are b16's, no? i know the 93 gs-r's are 1.7L
Old Mar 24, 2002 | 10:54 AM
ndustryalGSR's Avatar
Default Re: ticking after valve adjustment (Nighthawk GS-R)
Most of the time, you can find the valve adjustment specs listed on the sticker on the under-side of the hood. Check there to see if the specs you used were correct.
Old Mar 24, 2002 | 02:06 PM
ingrate's Avatar
25 Year Member
Default Re: ticking after valve adjustment (ndustryalGSR)
earlier b18a engines did have different valve lash specs.. go to integra.vtec.net and find the area about valve adjustments.. it has the specs for all of them in that page
Old Mar 24, 2002 | 03:01 PM
GSRaCeRbOI's Avatar
pop the hood and see if it has the clearance specs on that label that has all the info on spark plugs, catalyst, etc... if not.. maybe http://www.g2ic.com or some other Gen 2 integra related site might have the specs..
edit: this is taken from G2ic.com..
The 90-91 should be .006-.007 inches intake and .007-.008 inches exhaust
The 92-93 should be .003-.005 inches intake and .006-.008 inches exhaust.
try to verify w/ the sticker under you hood
[Modified by GSRaCeRbOI, 12:07 AM 3/25/2002]
Old Mar 24, 2002 | 10:10 PM
S13 slide's Avatar
Default Re: ticking after valve adjustment (GSRaCeRbOI)
what would that be in mm? my feeler gauge is in mm, thanks guys
Old Mar 24, 2002 | 11:08 PM
GSRaCeRbOI's Avatar
1" = 25.4mm so....
INTAKE:
.003"=.0762mm - .005"=.127mm
EXHAUST:
.006"=.1524mm - .008"=.2032mm
[Modified by GSRaCeRbOI, 8:17 AM 3/25/2002]
lowlife9
Honda Civic (2001 - 2005)
Sep 21, 2010 09:57 AM
infamouskillas
Jul 8, 2008 08:07 PM
prelude1897
Jun 26, 2005 01:58 PM
atikovi
Nov 4, 2002 08:50 AM
