headshake question....
Old Jan 29, 2006 | 05:54 PM
EngineNoO9's Avatar
Default headshake question....
been meaning to ask this. on my old 550cc bike I could let go of the bars and I'd keep going straight easy no problem and no shake at all... my superhawk though if I let go the bars will start shaking. Now my question is... Is this from the massive engine breaking going on (remember this is a v-twin liter bike) or is there a balance issue somewhere? Bike has never been dropped or laid down... I've never had shake any other time btw and the ride is buttery smooth...
Old Jan 29, 2006 | 07:54 PM
marmaladedad's Avatar
Might be your steering head bearings. The same thing happened on my FZ600.
Is everything torque'd down properly?
EngineNoO9's Avatar
Default Re: (marmaladeboy)
your superhawk doesn't do that??
and torqued down properly... no clue. I've not touched the suspension at all since buying it... the shop here put on my front brake rotors for me so I assume at least the wheel should be torqued properly...
Old Jan 29, 2006 | 08:01 PM
Default Re: (EngineNoO9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EngineNoO9 &raquo;</TD></TR><TR><TD CLASS="quote">your superhawk doesn't do that??
and torqued down properly... no clue. I've not touched the suspension at all since buying it... the shop here put on my front brake rotors for me so I assume at least the wheel should be torqued properly...</TD></TR></TABLE>
Mine doesn't shake its head at all...only on rare occasions exiting turns.
Go back and take a look at your bolts/axle nuts etc. I don't trust most shops to do the job right.
I don't remember what to check for the head bearings. If you have a service manual, you might try looking through that.
Old Jan 29, 2006 | 08:12 PM
D Day's Avatar
i am no mech but it sounds to me like maybe the head bearing have gone bad and that is causing some play in the front end.
EngineNoO9's Avatar
well see the thing I don't get is it doesn't shake in any other occasion but it kind've makes sense that it would since weight is being transfered to the front wheel under the heavy engine braking and nothing to keep the wheel straight...
Old Jan 29, 2006 | 08:13 PM
EngineNoO9's Avatar
I'll check it out when I get home... bike is in storage 400 miles away still and I won't see it for another few weeks.... how much u think that costs and how hard to replace??
Old Jan 29, 2006 | 08:17 PM
Does it only shake when the bike is decelerating? And only from high rpms?
Even so, I would still say, check the bearings. It shouldn't be too hard to check/replace, assuming you have the tools.
Old Jan 29, 2006 | 08:28 PM
EngineNoO9's Avatar
like I said I've never had it shake in normal riding. only will do so if I let go of both clip ons and just sit there with the engine braking. If I just let go of the throttle and hold on even in high rpm's it doesn't even attempt to shake.... like I said buttery smooth in all riding conditions except for when I let go of both bars... never tried dropping it to neutrall if I'm in second or something...
Old Jan 29, 2006 | 08:36 PM
Not to be so glib about it, but stop letting go of the handlebars during deceleration.
Old Jan 29, 2006 | 08:38 PM
EngineNoO9's Avatar
haha I only noticed it when I tried to adjust something like my helmet or gloves and kind've need two hands to quick do it. I thought it was the road and tried it again and noticed they started going side to side...
Old Jan 30, 2006 | 08:16 AM
BiffStroganoffsky's Avatar
Also check wheel balance...bad tire...incorrect psi.
Old Jan 30, 2006 | 02:32 PM
.RJ's Avatar
.RJ
Default Re: (BiffStroganoffsky)
Are the handlebars straight ahead when going down the road? Or are they off a little bit? Its possible the forks are bent too.
Old Jan 30, 2006 | 10:27 PM
EngineNoO9's Avatar
Default Re: (.RJ)
how on earth would they be bent?? never been dropped.... but yes they're straight
Old Jan 30, 2006 | 10:33 PM
big pete's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BiffStroganoffsky &raquo;</TD></TR><TR><TD CLASS="quote">Also check wheel balance...bad tire...incorrect psi.</TD></TR></TABLE>
+1
Old Jan 30, 2006 | 11:27 PM
EngineNoO9's Avatar
Default Re: (big pete)
I'll check everything out when i get back... is it safe to say though that if I go in second and drop to neutral and let go and I go straight that things are fine??
Old Jan 30, 2006 | 11:32 PM
I don't see how the engine braking would cause the headshake.
Let us know what you find out.
GraphiteAccord
Honda Motorcycles
33
Jun 11, 2008 09:57 AM
serious
Honda Motorcycles
Jun 11, 2007 12:42 PM
Veritas-Aequitas
Honda Motorcycles
14
May 9, 2006 08:33 AM
al4t1gbundy
Honda Motorcycles
10
Mar 7, 2005 09:53 PM
romeo619romeo
Honda Motorcycles
16
Jul 18, 2003 08:10 PM
