HOW to... change my Front Radiator support (searched)
Old Jan 29, 2006 | 05:32 PM
kraven9's Avatar
Default HOW to... change my Front Radiator support
I was in a little accident and my radiator support is bent and it needs to be removed. Any help would be great. Thanks.
Modified by kraven9 at 4:34 AM 1/30/2006
Old Jan 29, 2006 | 05:53 PM
LSEGHATCH's Avatar
Default Re: HOW to... change my Front Radiator support (kraven9)
not sure about the write up but i know you have to drill out the factory spot welds and weld in the new support
Old Jan 29, 2006 | 06:13 PM
turbotime's Avatar
1. remove bolts holding support to frame.
2. Use cobalt drill bit to drill out factory spot welds holding support to frame.
3. Replace with new support, re-spot-weld or use bolts in the previous spot weld holes
my roomate just did this on his car, its pretty easy- he doesnt know anything about cars and he did it
Old Jan 29, 2006 | 06:22 PM
kraven9's Avatar
Default Re: (turbotime)
Thanks to the both of you...but to turbotime what is a cobalt drill(I just did a search on ebay..is it special drill bits?). HOw would I bolt it back on..or should I weld it back on? What way is the best? Thanks.
Old Jan 29, 2006 | 11:57 PM
kraven9's Avatar
Default Re: (kraven9)
bump....anyone else? Your help will be greatly appreciated. Thanks.
Old Jan 30, 2006 | 07:51 AM
blue_dlb's Avatar
I believe he is talking about the drill bit. The drill bit is like the needle the drills into the metal. You can you any type of drills with that drill bit. I'd stay away from battery operated drills unless you have a powerful one. I'm going to be changing out my radiator support as well that's why i found this thread. You should definitely weld it back on.
Old Jan 30, 2006 | 08:56 AM
turbotime's Avatar
cobalt is just the material the trill bit is made of, you can get it at SEARS. Make sure you get a pretty big one, it has to be big enough to remove the spotweld completely.
Cobalt is teh best in my opinion, they have titanium too but i have broken so many titanium bits that i just use cobalt all the time now and save the money of buyiong and breaking a titanium bit
Old Jan 30, 2006 | 05:17 PM
kraven9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blue_dlb &raquo;</TD></TR><TR><TD CLASS="quote">I believe he is talking about the drill bit. The drill bit is like the needle the drills into the metal. You can you any type of drills with that drill bit. I'd stay away from battery operated drills unless you have a powerful one. I'm going to be changing out my radiator support as well that's why i found this thread. You should definitely weld it back on. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime &raquo;</TD></TR><TR><TD CLASS="quote">
Cobalt is teh best in my opinion, they have titanium too but i have broken so many titanium bits that i just use cobalt all the time now and save the money of buyiong and breaking a titanium bit </TD></TR></TABLE>
Thanks to the both of you. One more question where to get the radiator support from? I was thinking the junkyard but then they gotta take it off the car...then I was thinking aftermarket, but I don't know if I should go that route. Thanks.
Old Jan 30, 2006 | 05:27 PM
slammedej1's Avatar
jsut did mine 2 weeks ago strip everythig off the front drill out all oem spot welds n make sure when u put the new one back its strait measuser from holes on new support to fenders bolts n make sure all is good prime over welds so they dont rust out n when puttin everythig back make sure ur light grounds are tight
Old Jan 30, 2006 | 05:29 PM
slammedej1's Avatar
try to go OEM wit the new one or find where u can get new that u trust
Old Jan 31, 2006 | 05:37 PM
kraven9's Avatar
Default Re: (93 JDM eg6)
Aight. Thanks.
Old Sep 13, 2006 | 09:46 PM
maluseanjohn516's Avatar
hey guys sorry to butt in but do you guys know where are the spots where the spot welds and pictures could really help
Old Sep 13, 2006 | 10:30 PM
MattsGreenEG's Avatar
Default Re: (maluseanjohn516)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maluseanjohn516 &raquo;</TD></TR><TR><TD CLASS="quote">hey guys sorry to butt in but do you guys know where are the spots where the spot welds and pictures could really help </TD></TR></TABLE>
x2
Old Sep 14, 2006 | 03:41 AM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime &raquo;</TD></TR><TR><TD CLASS="quote">1. remove bolts holding support to frame.
my roomate just did this on his car, its pretty easy- he doesnt know anything about cars and he did it</TD></TR></TABLE>
Definately the way.
Just, bolt it before you weld it, the bolts will hold it in place - it'll make it a whoreload easier to weld.
boostedef123
Mar 21, 2012 04:04 PM
FormulaIntegra
Nov 4, 2009 12:00 PM
JCracer723
Jun 10, 2006 07:27 PM
beyondspexj
Dec 18, 2005 08:28 AM
EF_LSVtec
14
Jun 28, 2002 09:13 PM
