Grinding in 5th Gear
Old Jan 29, 2006 | 03:42 PM
tcontesh's Avatar
Default Grinding in 5th Gear
I have a 97' SH which has pretty much started grinding in 5th gear recently after I purchased the car. the grinding is not terribly bad but it still sucks. everyone that rides in my car mentions it. if anyone has had a similar problem, or has fixed the problem please let me know.
Old Jan 29, 2006 | 04:48 PM
preludeMOM's Avatar
Default Re: Grinding in 5th Gear (tcontesh)
I just ordered an h22a w/ LSD tranny, and I have a suddle grind into 5th gear. No one has noticed it yet, but I can feel it.
Old Jan 29, 2006 | 04:55 PM
lude98SH's Avatar
Default Re: Grinding in 5th Gear (preludeMOM)
I noticed that if im tearing through my gears and try to put it in 5th the same way you put it in 3rd (moving across/on an angle), then I grind. But if i move the shifter to the right first and then up into 5th it doesnt grind. >^ in that motion into 5th. Maybe my tranny is fine idk hope maybe that helps.
Old Jan 29, 2006 | 05:11 PM
94Vtecluder's Avatar
Default Re: Grinding in 5th Gear (lude98SH)
Try using synchromesh tranny fluid. I've heard it do wonderings including fix grinding gears.
Old Jan 29, 2006 | 05:14 PM
lude98SH's Avatar
Default Re: Grinding in 5th Gear (94Vtecluder)
either that or just change your tranny fluid using Honda MTF. How many miles on the trans ? Any issues with syncros or anything ?
Old Jan 29, 2006 | 06:17 PM
SteveoBA8's Avatar
TSB(tech service bulletin) accord/lude 5th gear upshift grind.
Old Jan 30, 2006 | 09:31 AM
tcontesh's Avatar
I have never changed the fluid, so that might help.
I guess the 5th gear grinding is quite common with accords and Ludes.
does anyone know if there was any recalls or anything.
Old Jan 30, 2006 | 09:58 AM
BlackBird_SC61's Avatar
5th was the first gear to grind in mine. Unfortunately from there it went downhill and I ended up needing a whole new tranny. After 5th, 3rd started grinding. I used Honda MTF the whole time (which is basically motor oil). However, it took a long time for this to happen. Hope your's isn't as bad.
Old Jan 30, 2006 | 12:37 PM
JDM4DRACCORD's Avatar
YOU HAVE NEVER CHANGED YOUR FLUID? THAT IS A GOOD WAY TO expletive UP YOUR TRANNY. THUMBS UP TO YOU DUDE!
indtegra
Nov 5, 2007 07:22 AM
bboyfreeze
Mar 26, 2007 06:41 AM
WhiteVX
May 19, 2006 04:37 PM
ragerized
Jul 11, 2004 03:53 PM
John
Feb 12, 2002 12:16 PM
