dohc zc internals
Old Jan 29, 2006 | 03:42 PM
nappyroots827's Avatar
Default dohc zc internals
hey, im getting ready to build a dohc zc motor... and i want to know what aftermarket rods i can use...Can i use them from any d series motor, or does it have to be from a d16a1 integra motor, also, anyone know a good place to get cheap stock compression pistons?
Old Jan 31, 2006 | 01:37 PM
Default Re: dohc zc internals (nappyroots827)
bump dat sheet
Old Jan 31, 2006 | 02:47 PM
jlicrx's Avatar
rods for D16A6, D16A1, D16Z6, etc.
pistons:
http://cgi.ebay.com/CIVIC-DOHC...wItem
Old Jan 31, 2006 | 04:15 PM
ludesrv's Avatar
B18A (LS) rods work too. You will need to machine your crank to accept them.
Old Jan 31, 2006 | 04:22 PM
jlicrx's Avatar
Default Re: (ludesrv)
actually, the big end of the LS rod is wider than the D-series, so you need to cut down the rod width in order to fit the crankshaft - big end bore is same - LS rods also have a larger diameter pin and won't work with stock type D-series pistons
Old Jan 31, 2006 | 04:38 PM
91whiteZCrex's Avatar
Default Re: (jlicrx)
acutally, once again, someone forgets to say some IMPORTANT information, doesnt seem iregular from some of you idiots, when you bild a dohc you need to dremel or file some of the block on the inside or the rods will not have enough 360 clearence to rotate around.
Old Jan 31, 2006 | 06:41 PM
crxrocks's Avatar
Default Re: (91whiteZCrex)
That all depends on the rods you use.
BTW> That is no different than using "those" rods in a d16a6.
Old Feb 2, 2006 | 02:48 PM
Default Re: (crxrocks)
alright so lemme get this, i can use any aftermarket rods from a d16a6? im gonna need to cut some of the block??????? Also, i read on nopionline.com, that the pin diameter is a bit different from the a6 to the z6 to the y8..... and one more thing, if i do but a new oem oil pump for the rebuild...which one do i use? teg or crx? or do i have to use the zc one...? sorry for all the questions, i just wanna do this right the first time so i don't have to rip the motor out again...
Old Feb 2, 2006 | 02:59 PM
jlicrx's Avatar
Default Re: (nappyroots827)
all D16 (including ZC) rods are the same - they do not have different pins - Eagle rods makes 2 different D-series rods - one with 5/16" bolts which do not require notching the block (which isn't a big deal) and one with 3/8" bolts which do require notching of the block - if you were to use the LS rods, they have a bigger pin and need milled on the big end to fit the crank - all internal parts on the ZC below the top of the block are the same as the D16A6, except for the timing belt
Old Feb 2, 2006 | 05:46 PM
crix351c's Avatar
i dont think they make the 5/16 rods anymore buddy...they upgraded to the bigger for more strenfth
Old Feb 2, 2006 | 09:28 PM
Default Re: (crix351c)
okay so front and rear seal, oil pump, water pump are all gonna be crx parts then?
Old Feb 3, 2006 | 02:56 AM
VegaS10's Avatar
http://www.thezcr.com
They have a list of all internal and external parts sticked in their "ZC Discussion" section.
Old Feb 3, 2006 | 07:49 AM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nappyroots827 &raquo;</TD></TR><TR><TD CLASS="quote">okay so front and rear seal, oil pump, water pump are all gonna be crx parts then?</TD></TR></TABLE>
yes, but as VegaS10 said, visit http://www.thezcr.com for all your ZC questions - all ZC (mostly), all the time
Old Feb 3, 2006 | 08:09 AM
rewerbcrx's Avatar
eagle pistons and rods! next winter thats what i will be placing in my baby.
Old Feb 3, 2006 | 09:07 AM
da9wonder's Avatar
bump
Old Feb 6, 2006 | 07:33 AM
Default Re: dohc zc internals (crxwonder)
anyone aware of a company that makes zc pistons that would be good for like a 7psi turbo job?? cuz i found a compression calculator for dseries motors, and every other d series motor piston will give me no more than like 8.2:1 which is way lower than i wanna go, so i was just thinking go stock compression and have a machine shop grind off some of the dome and bring me down to around 9.2 or 9.3...but if i have other options please lemme know...
Old Feb 6, 2006 | 08:39 AM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nappyroots827 &raquo;</TD></TR><TR><TD CLASS="quote">anyone aware of a company that makes zc pistons that would be good for like a 7psi turbo job?? cuz i found a compression calculator for dseries motors, and every other d series motor piston will give me no more than like 8.2:1 which is way lower than i wanna go, so i was just thinking go stock compression and have a machine shop grind off some of the dome and bring me down to around 9.2 or 9.3...but if i have other options please lemme know... </TD></TR></TABLE>
SRP makes a piston for the D16A6 with 4.3cc dome which should get you about where you want to be for compression ratio - around 9.4:1 - just remember when you enter this into compression calculator to use piston to deck height for the D16A6 and not the ZC
http://www.crower.com/cat/impo...shtml
Ronin Panda
Jun 1, 2003 02:02 PM
ZCcivic91
12
May 8, 2003 02:04 PM
SM 30 Hatch
Sep 24, 2002 12:32 PM
ZColeon
Apr 26, 2002 10:35 PM
