motor runs strange after jumper harness install
I just put an obd0-obd1 jumper harness in my 88 ef, the motor revs, runs kind of rich as well, when i hover around 3.5k, the motor feels likes its hitting a rev limiter. what could it be.
Also, does anyone haveinstruciotns on how to install the service connector?
D4 | BRN/WHT | SCS | service check connector | -> mil [toggle switch with ground]
TIA
TIA
for the service connector you run that wire to a normally open switch. Run another wire to ground.
Close the switch to check codes.
so in this case, do you mean, the open switch .. d4, then connect it to a switch, that has a ground( that would be a switch, i know, but i want to be clear) and then flip the switch( close the switch) or ground the switch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by court »</TD></TR><TR><TD CLASS="quote">so in this case, do you mean, the open switch .. d4, then connect it to a switch, that has a ground( that would be a switch, i know, but i want to be clear) and then flip the switch( close the switch) or ground the switch</TD></TR></TABLE>
run a wire from d4 to the common terminal on the switch, run another wire from the normally open terminal to ground. Flipping the switch will complete (close) the circuit.
g2turbo
Engine Management and Tuning
Jun 22, 2014 04:26 AM
type Gendy
Aug 31, 2005 06:09 PM
