How does my clutch look?
Old Jan 29, 2006 | 02:17 PM
huntarrr's Avatar
Default How does my clutch look?
swapping motors in my car.. open up the tranny and walla, i found out i have an daikin/exedy clutch looks like just an OEM replacement, but was wondering how it looked. should i get a new one or will this last me for another year?
me and ricey goin at it
Old Jan 29, 2006 | 02:23 PM
tallyturbo's Avatar
Default Re: How does my clutch look? (vsm98civic)
if it were me and i had the extra cash i would get a new one. that way you dont have to worry about replacing it for a while.
Old Jan 29, 2006 | 02:25 PM
huntarrr's Avatar
Default Re: How does my clutch look? (tallyturbo)
i know.. i just dont want to have to spend the money if i dont have to... i'll only be driving this car until december... so i'd put about another 10,000 miles on it/the clutch.
Old Jan 29, 2006 | 02:37 PM
dohcVTECeg2's Avatar
u run the risk of it going bad once installed and then replacing it again and dropping the tranny
Old Jan 29, 2006 | 02:53 PM
huntarrr's Avatar
Default Re: How does my clutch look? (dohcVTECeg2)
.....yes i realize this, but if the clutch is in good condition, there is no reason why it would fail.
Can anyone tell me about how much life is left on my clutch???
Old Jan 29, 2006 | 02:58 PM
tallyturbo's Avatar
well if thats the case i would just slap that puppy back in there and give it a go. it doesnt look to bad imo. good luck
P.s. when i pulled my old d15 my clutch looked way worse than that one, and it ran without any problems
Old Jan 29, 2006 | 02:59 PM
huntarrr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tallyturbo &raquo;</TD></TR><TR><TD CLASS="quote">well if thats the case i would just slap that puppy back in there and give it a go. it doesnt look to bad imo. good luck</TD></TR></TABLE>
Thank you, that was the type of response I was trying to get.
Anyone else have opinions?
Old Jan 29, 2006 | 03:08 PM
sbowers's Avatar
well you dont seem too worried about it and ive seen worse clutches be reinstalled and last so run it but it would sure be nice to knock it all out at once
Old Jan 29, 2006 | 03:39 PM
upstatee's Avatar
Default Re: How does my clutch look? (sbowers)
looks like its got alot of life, clean up the pressure plate though.
Old Jan 29, 2006 | 03:58 PM
.Kevin.'s Avatar
Default Re: How does my clutch look? (upstatee)
you are to poor to buy a 90$ clutch why ask if that was the response you wanted was to just keep it. that clutch looks like it has a lot of wear way more than my 100k clutch that i replaced
Old Jan 29, 2006 | 04:03 PM
huntarrr's Avatar
Default Re: How does my clutch look? (Slow_CvC99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow_CvC99 &raquo;</TD></TR><TR><TD CLASS="quote">you are to poor to buy a 90$ clutch why ask if that was the response you wanted was to just keep it. that clutch looks like it has a lot of wear way more than my 100k clutch that i replaced</TD></TR></TABLE>
No i'm not too poor to buy one, but why spend money if I dont have to? If this clutch has 20k left on it, i'll throw it back in... if it has 3k, i'll swap it. Also, I dont know if it's worth the downtime... i gotta get this car back on the road and getting another clutch would take another week....
I didn't want people to tell me to keep it. i was asking for that TYPE of response. One of the two answers:
1. it looks like it's got some life left, use it.
2. looks a little worn, you should replace it.
pick one.
Old Jan 29, 2006 | 04:19 PM
huntarrr's Avatar
expletive it... found a new Exedy replacement on ebay for $80 shipped.
Old Jan 29, 2006 | 04:20 PM
FuNkDrSpOt's Avatar
Just measure the clutch thickness. If its 5.5 mm then replace. A new clutch will have 8.5 mm - 9.1 mm of thickness.
From the looks of it, it seems as though the clutch will work for 10k.
Old Jan 29, 2006 | 04:32 PM
huntarrr's Avatar
Default Re: How does my clutch look? (FuNkDrSpOt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FuNkDrSpOt &raquo;</TD></TR><TR><TD CLASS="quote">Just measure the clutch thickness. If its 5.5 mm then replace. A new clutch will have 8.5 mm - 9.1 mm of thickness.
From the looks of it, it seems as though the clutch will work for 10k. </TD></TR></TABLE>
Perfect response, thanks.
Old Jan 29, 2006 | 04:34 PM
Civic4less's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vsm98civic &raquo;</TD></TR><TR><TD CLASS="quote">expletive it... found a new Exedy replacement on ebay for $80 shipped.</TD></TR></TABLE>
I got one for 74$ shipped.
Your's looks pretty fine? A HELL of a lot better then the one I pulled out of the spare y7 I had.
Old Jan 29, 2006 | 04:54 PM
.Kevin.'s Avatar
Default Re: How does my clutch look? (Civic4less)
see there you go
autozone i think has them 4 like 100$
Old Jan 29, 2006 | 05:03 PM
JeffBro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow_CvC99 &raquo;</TD></TR><TR><TD CLASS="quote">see there you go
autozone i think has them 4 like 100$</TD></TR></TABLE>
Don't buy a clutch from autozone. Get the exedy replacement or street clutch. At least thats what I would do if it was me.
Old Jan 29, 2006 | 05:57 PM
Ricey McRicerton's Avatar
Default Re: How does my clutch look? (JeffBro)
Replace it Hunter. I'm not interested in dropping the tranny agian.
Actually, get it mic'ed and see how thick it is. You might not need to do anything to it.
BauleyCivic's Avatar
Risky Business
Default Re: How does my clutch look? (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">Replace it Hunter. I'm not interested in dropping the tranny agian. </TD></TR></TABLE>
Dude its fun. I did mine like 4 times in 6 months...stupid input shaft seal
Old Jan 29, 2006 | 05:59 PM
Default Re: How does my clutch look? (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">
Dude its fun. I did mine like 4 times in 6 months...stupid input shaft seal </TD></TR></TABLE>
I've had mine off 3 times. I'm not interested in doing them any more than I have to.
Old Jan 29, 2006 | 06:01 PM
huntarrr's Avatar
Actually, get it mic'ed and see how thick it is. You might not need to do anything to it.</TD></TR></TABLE>
Already bought one on ebay
More downtime... ****! Appreciate the help today though
Old Jan 29, 2006 | 06:03 PM
More downtime... ****! Appreciate the help today though </TD></TR></TABLE>
No big deal. We'll get it all put back in next weekend. Just call me earlier so we have some more time.
Go get some damn PB Blaster and some kind of teflon spray before we put anything back together too.
Old Jan 29, 2006 | 06:06 PM
huntarrr's Avatar
I dont wake up earlier on the weekends
im gonna come home during the week whenever i can to work on it a little... hopefully i'll have the new clutch and the tranny bolted on so everything will be ready to just drop in by next weekend. but you know how **** goes
Old Jan 29, 2006 | 07:09 PM
FuNkDrSpOt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">Dude its fun. I did mine like 4 times in 6 months...stupid input shaft seal </TD></TR></TABLE>
I wondered who was under that Burger King King mask and robe...now I know. I'm a big fan of your commercials King.
Old Jan 29, 2006 | 07:55 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vsm98civic &raquo;</TD></TR><TR><TD CLASS="quote">I dont wake up earlier on the weekends
im gonna come home during the week whenever i can to work on it a little... hopefully i'll have the new clutch and the tranny bolted on so everything will be ready to just drop in by next weekend. but you know how **** goes </TD></TR></TABLE>
Well get me on a Saturday or something then man. I'll stay as late as it takes on a Saturday as long as I can crash back at your place instead of driving all the way home. Sunday nights suck for me.
