h23 intake mani?????
Old Jan 29, 2006 | 11:34 AM
ludaboy93's Avatar
Default h23 intake mani?????
ive been searching and cant find any aftermarket intake manifold for h23 non vtec motors. Does anyone even make them?
Old Jan 29, 2006 | 11:35 AM
The Weather Man's Avatar
..........what mods do you have done to your car already?...........I would suggest having yours ported along with the TB opening widened.
Old Jan 29, 2006 | 12:23 PM
ludaboy93's Avatar
Default Re: (TheKINGPin)
aem intake megan headers 4-2-1 Full exhaust system 2.25 piping and thats preatty much it. around how much does it cost to get the intake manifold ported and polished
Old Jan 29, 2006 | 12:54 PM
ludaboy93's Avatar
Default Re: (ludaboy93)
Old Jan 29, 2006 | 01:02 PM
AndyD's Avatar
You need more mods before you can justify an upgraded intake manifold.
Old Jan 29, 2006 | 01:12 PM
ludaboy93's Avatar
Default Re: (AndyD)
thats true but iam planning to continue to put a bit more money under the hood. so i needed to sooner or later see if there is an intake manifold made to fit h23's
Old Jan 29, 2006 | 01:19 PM
AndyD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludaboy93 &raquo;</TD></TR><TR><TD CLASS="quote">thats true but iam planning to continue to put a bit more money under the hood. so i needed to sooner or later see if there is an intake manifold made to fit h23's</TD></TR></TABLE>
Worry about it when you finally need it!
Too many people mod their car for the future. Trust me, it RARELY happens that people build what they plan. Hell, just build a G23 non-VTEC and you will get more power out of that than you will from your H23, no matter what you do to it!! If the G23 isn't an option, don't worry about the IM and build the head and get cams.
Seriously, there are other worthwhile mods out there compared to the IM. The F23 bottomend is a better mod than the intake manifold.
Old Jan 29, 2006 | 01:25 PM
ludaboy93's Avatar
Default Re: (AndyD)
eh dude thanks for the input about the intake manifold. i have a question though. i have a aem cold air intake that i just put on the other day and when i put it on i took apart the throttle body to clean it cuz it was really grimmy. After putting everything back together i noticed a pretty loud whistle sound everytime i accelarate or tap the gas? what is causing this?
Old Jan 29, 2006 | 04:09 PM
ludaboy93's Avatar
?anyone
Old Jan 29, 2006 | 04:24 PM
AndyD's Avatar
Are you sure there isn't a leak when you took the TB off? TB gasket not seated properly? That's the only place where I would think it is coming from.
As for your motor build, if you want to build an all-motor non-VTEC engine, read Pirate McFred's thread about the G23. It's the best platform to start off with. As I always say, do it right the first time. It is cheaper and less frustrating that way.
Old Jan 29, 2006 | 04:34 PM
ludaboy93's Avatar
Default Re: (AndyD)
noo im pretty sure there is no leak everything is fit to perfection when i put it back on. i tried playing around with the idle air valve but that just brought my idle higher. so i put that back to normal.. i dont know what it could be. im bent.
PrecisionH23a's Avatar
Default Re: h23 intake mani????? (ludaboy93)
Golden Eagle makes one for the h23a
Old Jan 29, 2006 | 04:49 PM
ludaboy93's Avatar
Default Re: h23 intake mani????? (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">Golden Eagle makes one for the h23a</TD></TR></TABLE>
thnx any input on this whistle sound i caused
Old Jan 29, 2006 | 05:43 PM
GaRn's Avatar
take the intake off and put it back on, slightly repositioned.. I have heard of this happening and it just being a resonance that is fixed once things are moved around..
Old Jan 29, 2006 | 05:51 PM
ludaboy93's Avatar
Default Re: (GaRn)
really. thats odd. but ill give it a shot
Old Jan 29, 2006 | 05:55 PM
If there's a whistle - there's obviously a small opening some where. Just reposition everything - did you take the TB off previously?.........are you using two hose clamps on your intake coupler?
Old Jan 29, 2006 | 06:09 PM
ludaboy93's Avatar
yes i took the throttle body off when i installed the intake to clean it. someone mentioned to me it might be the idle air screw but thats not the case
Old Jan 30, 2006 | 05:43 AM
championshipwhite93si's Avatar
*gasp* golden eagle makes a manifold for my h23... i did not know that.. thanks!!!!!!!
Old Jan 30, 2006 | 08:43 AM
Hawkze_2.3's Avatar
Default Re: (championshipwhite93si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by championshipwhite93si &raquo;</TD></TR><TR><TD CLASS="quote">*gasp* golden eagle makes a manifold for my h23... i did not know that.. thanks!!!!!!!</TD></TR></TABLE>
It's for turbo applications, though. It's not going to gave you any power to just bolt one on a basically stock engine...
DareOh
Mar 8, 2008 08:39 AM
jacob_kohler
Jul 19, 2007 04:27 PM
fastazzf22
Jul 15, 2007 02:23 PM
fast93accord
Jun 17, 2003 06:51 PM
user 9782082308
Feb 19, 2003 09:15 PM
