Belt Under Alternator~~HELP
ok, well when i was driving this belt came off and then the battery light came on. Its the belt for the alternator and the one next to it... Well the next day when i put the belt back in its place, the car started making this loud squeaking noise....Does anybody know why this is and how do i get rid of this noise or what the cause of this noise is???
Pictures will be up momentarily....
Modified by hennessy at 12:30 PM 1/29/2006
Vic, I'm gonna forgo the "crystal ball" cracks and the one about "I can't see what car you've got from here" either; but if you could give a clue, it will help.
I'm going to take a guess:
either the belt isn't tighten enough. or
All F22 / F23 4cylinder from '94 thru '00 (LX,SE,EX) utilize two accessories drive belts. One drives the Power Steering Pump (Top-most on the motor) and the second belt drives both the Alternator and the A/C Compressor.
Either you've an issue with the A/C pulley bearing (failed and locked up) or the compressor siezed.
P
P
its a 91' ex and when i start the car it makes the noise but when i drive off it stops, then when i stop at a light and turn it starts making the noise again....need help this noise is killing me...
higgunscrx
Jun 15, 2006 05:11 PM
