Function7 LCAs and Honda Bolts?
Old Jan 29, 2006 | 07:29 AM
Cyclonium's Avatar
Default Function7 LCAs and Honda Bolts?
Just messing around with the arms last night, not fitting them or anything but noticed the the honda bolts are tight in them, they wont go through, prob will if you give them a tap.
I am wondering are you supposed to use honda bolts with them and should they be an interference fit or not.
Old Jan 29, 2006 | 07:32 AM
beyondspexj's Avatar
you should be able to use honda bolts. just give em a love tap or two!
Old Jan 29, 2006 | 07:38 AM
Cyclonium's Avatar
Default Re: (beyondspecs_jamar)
LOL think I will. Cheers for that.
Old Jan 31, 2006 | 10:23 AM
DavidR's Avatar
Default Re: Function7 LCAs and Honda Bolts? (Cyclonium)
I used Honda bolts on my car, everything works perfectly. Perhaps your bolts have some rust on them? I would also always use Anti-Seize on the bolt shaft.
Old Jan 31, 2006 | 10:40 AM
Cyclonium's Avatar
Default Re: Function7 LCAs and Honda Bolts? (DavidR)
Nope brand new, the old ones did have some rust though
The threaded bit goes up fine but after that it gets tight, ah ill see when i get around to putting it together. Its just tight but didnt want to force it said id ask first incase it was done on purpose and that F7 made bolts for it.
Old Jan 31, 2006 | 11:37 AM
stockbee's Avatar
Generally, and you problably already know this but when replacing any kind of suspension component, from lca's to front shock forks or anything, things are going to be tight when putting them back together. good luck, those are good looking lca's.
andyz
Suspension & Brakes
23
Apr 10, 2012 12:11 PM
98Luder
Suspension & Brakes
Nov 13, 2009 08:24 PM
Samuels
Suspension & Brakes
13
Jun 27, 2006 04:54 PM
