brake upgrade
Old Jan 29, 2006 | 07:10 AM
djxtc65's Avatar
Default brake upgrade
i cant get a stright answer so ill try and ask again
i have an 89 std all stock and i want to upgrade the brakes before i do the motor swap and turbo
i have a wrecked 95 coupe ex with brand new rotra drilled and slotted rotors and axis pads
they only have at the most 2000 miles on the now can i use the if so do i need to use the calapers and any other parts from my 95 i also have a 89 si that is my parts car also but they are both rear drum (booo )
but can some one please tell me what i can do
also will a prelude master cylinder help too i heard that some where if so what year would i need
thank you
Old Jan 29, 2006 | 07:14 AM
Pee Wee's Avatar
Default Re: brake upgrade (djxtc65)
https://honda-tech.com/zero...ge=12
Old Jan 30, 2006 | 08:15 AM
djxtc65's Avatar
Default Re: brake upgrade (EF8opey)
anyone elce
Old Jan 30, 2006 | 08:23 AM
CRX Toad's Avatar
So what do you want then?
You can do EX/DA Spindles with ITR/NSX/Legend/Accord Wagon with redrilled prelude rotors with DA booster and master cylinder.
Old Jan 30, 2006 | 12:07 PM
djxtc65's Avatar
Default Re: brake upgrade (CRX Toad)
i like that idea bit im trying to do it with what i have at my shop
the brakes i was to upgrade 89 std
the cars i have the parts on
95 civic ex coupe with rotra drilled and slotted rotors and aixs pads with like 1500miles on it
and a 89 si for whatever else i need
can i do this
Old Jan 30, 2006 | 01:45 PM
LSvtec03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF8opey &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zero...ge=12</TD></TR></TABLE>
exactly what i did.
si discs on the back, these up front. easy. cheap. effective.
CDStreetSleeper
Mar 8, 2013 06:53 AM
Kidnkorner
Dec 7, 2009 03:06 PM
MrEG6er21
Jun 23, 2003 08:12 AM
Driven
20
Mar 31, 2003 04:42 PM
