Converting a/c from R12 to R134a
Old Jan 29, 2006 | 06:59 AM
PphamEK's Avatar
Default Converting a/c from R12 to R134a
Hi i have a 92 prelude and i am goin to convert my a/c to r134a. To be able to do that , would i was to change out the rest of my component like my reciever dry, evaoprator, condensor, txv valve, or thermalstatic switch? Cuz i no ur not suppost to mix those 2 refregerant together.
Old Jan 29, 2006 | 08:46 AM
junbb1's Avatar
Default Re: Converting a/c from R12 to R134a (MugenedEK)
no. just recover and put into a long vacum. go buy the retrofit kit from honda. they can give you a print out of the service bulliten and it will give you detailed instructions on how to install it and the proper steps you need to take.
Old Jan 29, 2006 | 08:54 AM
hondabigblock's Avatar
Default Re: Converting a/c from R12 to R134a (junbb1)
If you have r12 and it works leave it alone that would be like taking a mugen part off and putting an obx on
Old Jan 29, 2006 | 09:16 AM
The Weather Man's Avatar
Default Re: Converting a/c from R12 to R134a (hondabigblock)
I think all you have to do is evacuate the system for a good long time.
Change the service fittings.....
Put the r134a sticker on the car - and remove the r12..........
Charge with R134a - and make sure you use the Esther oil or whatever......
maybe i'm wrong though.
uh, you might have to change to the receiver dryer though. I'll try to look everything up for you.
Old Jan 29, 2006 | 12:05 PM
PphamEK's Avatar
normal vac is 30 min, should i vac it for an hr then?
Modified by MugenedEK at 1:24 PM 1/29/2006
Old Jan 29, 2006 | 05:32 PM
ed_1's Avatar
You could leave the condenser and evaporator on. Another suggestion would be if you get AC lines of a 94 and up prelude, and compressor i think you could get away with the txv. You are going to need pag oil. But if your AC doesnt work than you have a leak, cuase you can't run out of freon, unless when you got the car the previous owner evacuated the system or something. You could use the same compressor if you replace the o rings on it, or something like that.
Old Jan 29, 2006 | 05:49 PM
Yeah - evacuate the system longer than 30min - i'd do atleast an hour. You have to get everything out of there.
The oils are not "supposed" to mix - but a lot of people I know have been running the mineral oil with the r134a - and they've held fine. They all had GM vehicles though - so just get the pag or esther oil.
91prelude4me
Apr 24, 2012 01:11 PM
aldera
Honda CR-V & Element
Aug 14, 2010 07:55 AM
dchi_t
May 8, 2003 10:00 AM
ation
Apr 24, 2003 06:01 PM
magic hat #9
Jan 30, 2002 05:15 AM
