Who's using A032R for AutoX?
For people who are using A032R (205/50/15) for AutoX.
What tire pressure did you find the best for AutoX??
How can you tell if you got too much psi?
Thanks
Thanks
start at oem pressures, then look at the sidewalls to see how far down you are scuffing them, increase tire pressures a bit to avoid scuffing the sidewall.
play around a bit, it is different for every surface and suspension setup...
also try starting high and work your way down.
I think I ran 36 f 40 r but I'm not sure....
try the competition forum, but they will most likely suggest you find your best settings regardless of what they use.... unless you have an identical susp setup as someone in there.
rice r0cket
Oct 6, 2003 09:40 PM
VTECAcuraGSR
21
Apr 16, 2003 02:20 PM
SoloSol
Oct 15, 2001 05:57 AM
