Honda S2000 Honda S2000
Brake Fluid Recommendations for the S2000
Old Jan 29, 2006 | 05:35 AM
TommyV's Avatar
Default Brake Fluid Recommendations for the S2000
I tried searching, and didn't find any topics specifically for the S2000. My brake fluid and clutch master cylinder fluid are in desparate need of changing. I do some autocrossing, and evenutally I'd like to do some road racing since I'm near Limerock Park and I know people who have done it and they love it.
Do anyone have any recommendations on brake fluid that won't damage the braking system. I've heard Motul Dot 3 is really good.. ideally I want something better then the stock fluid, something that will resist brake fading better.
Any advice?
Old Jan 29, 2006 | 06:51 AM
SuzukaBlueAP2's Avatar
Default Re: Brake Fluid Recommendations for the S2000 (TommyV)
ATE super blue
or Motul
both are great. Motul is a tad mor expensive.
Old Jan 29, 2006 | 10:03 AM
00MRSi's Avatar
Default Re: Brake Fluid Recommendations for the S2000 (ScreaminTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScreaminTeg &raquo;</TD></TR><TR><TD CLASS="quote">ATE super blue
or Motul
both are great. Motul is a tad mor expensive.</TD></TR></TABLE>
Both are good. Motul is very expensive. I heard Valvoline makes a good synthetic brake fluid, also readily available in stores.
Old Jan 30, 2006 | 02:50 PM
Mr. Bagel's Avatar
Default Re: Brake Fluid Recommendations for the S2000 (00MRSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00MRSi &raquo;</TD></TR><TR><TD CLASS="quote">Both are good. Motul is very expensive. I heard Valvoline makes a good synthetic brake fluid, also readily available in stores. </TD></TR></TABLE>
Watch what you put in there!
Synthetic doesn't always mean "good" or "better". Most synthetics that I've seen (and I could be very wrong) are DOT 5, which is NOT compatible with DOT3 or DOT4 systems. Cars are DOT3, and DOT4 fluids, most of them, are compatible with DOT3.
If you recommend ATE Super Blue or Motul 600, you should also preface why: it has a higher boiling point. This means you will not boil your brakes. But if you only drive on the street, or even the twisties, you will never, and I mean never, reach a boiling point. Heck, not even in an autocross. Having a higher boiling point, the fluids are also more prone to condensation and water. This is bad. This will make your brakes turn to mush after a while. Bleeding the brakes will need to be done a few times a year. If you are sitting there saying to yourself, "nah, it aint so!" Well, try to bleed your brakes tomorrow, tell me if there is a difference.
BTW, a good deal would be Ford Heavy Duty. It is cheap and works great. If it is a dedicated track car, there are also 70 bottles of fluid out there if you really want the best stuff. It isn't worth it. Ford HD works just fine fine fine.
Best of luck.
Old Jan 30, 2006 | 02:55 PM
devnull's Avatar
And I would suggest better brake pads and SS lines first before buying motul BF. Valvoline Syn Brake fluid is DOT 3/4 and boiling is near 500 dry (I think dry?).
Old Jan 30, 2006 | 03:31 PM
Chubz's Avatar
Default Re: (badboypolar2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by badboypolar2 &raquo;</TD></TR><TR><TD CLASS="quote">And I would suggest better brake pads and SS lines first before buying motul BF. Valvoline Syn Brake fluid is DOT 3/4 and boiling is near 500 dry (I think dry?).</TD></TR></TABLE>
agreed/\/\
Old Jan 31, 2006 | 08:09 AM
TommyV's Avatar
Default Re: (Chubzilla)
Ok you guys have conviced me to stick with the Stock Honda fluid for now... since I won't be road racing this year or next either, unless I hit the lotto....
Plus if I'm extremely luckly I'll be able to buy new pads and rotors this year.. but maybe not.
Either way the fluid has to be changed, so I guess I'm gonna stick stock Honda and yes, I don't mind paying 5 extra bucks just to see Honda on the label. I know it's the right fluid!
Thanks all for your opinions / recommendations
Old Jan 31, 2006 | 03:54 PM
granracing's Avatar
I'll second ATEs brake fluid. I use this stuff for all of my cars. Not only is it great brake fluid, it is also relatively inexpensive. The other nice thing is that you can buy ATE one time (amber color) and Super Blue (same company but the fluid is blue). This ensures that you fully flush the fluid.
Tommy, you should check out some of the LRP SCCA events! As for HPDEs at LRP, SCDA is top notch. Hope to see you at the track some time.
Old Jan 31, 2006 | 06:46 PM
Mr. Projekt's Avatar
* B A N N E D *
I use Motul RBF600 DOT 5.1
Old Jan 31, 2006 | 07:42 PM
-iLLuZioN-B18C1's Avatar
Default Re: Brake Fluid Recommendations for the S2000 (Slideways2000)
ate superblue for me too
Old Feb 1, 2006 | 10:43 PM
sk8flex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slideways2000 &raquo;</TD></TR><TR><TD CLASS="quote">I use Motul RBF600 DOT 5.1</TD></TR></TABLE>
Motul RBF600 is DOT 4.
Old Feb 3, 2006 | 12:53 PM
* B A N N E D *
Default Re: Brake Fluid Recommendations for the S2000 (sk8flex)
My apologies. I forgot to type OR, which would make it look like so:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slideways2000 &raquo;</TD></TR><TR><TD CLASS="quote">I use Motul RBF600 or DOT 5.1</TD></TR></TABLE>
Old Feb 9, 2006 | 09:54 PM
mitmaks's Avatar
heard good stuff about ATE
DC4R27
Dec 2, 2009 10:03 AM
RaceMyGhost
Jan 12, 2006 11:09 AM
panykus
Honda S2000
10
Aug 28, 2004 01:43 PM
blkgsr03
Apr 16, 2004 09:21 AM
jdm92accord
Jan 30, 2002 09:29 AM
