DPFI to MPFI
Old Jan 28, 2006 | 10:52 PM
2kTeg's Avatar
Default DPFI to MPFI
So i've done a lot of research and i pretty much find all the sites i need to do this swap... but my question is..
I have a full SI engine harness..... would it be easier to use this or actually do the conversion on the DX harness using some of the plugs from the SI harness...
Old Jan 28, 2006 | 10:54 PM
lvzero0's Avatar
Default Re: DPFI to MPFI (2kTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2kTeg &raquo;</TD></TR><TR><TD CLASS="quote">So i've done a lot of research and i pretty much find all the sites i need to do this swap... but my question is..
I have a full SI engine harness..... would it be easier to use this or actually do the conversion on the DX harness using some of the plugs from the SI harness... </TD></TR></TABLE>
http://tech.hybridgarage.com/t...g.htm
Old Jan 28, 2006 | 10:59 PM
court's Avatar
25 Year Member
Default Re: DPFI to MPFI (lvzero0)
i found it much easier to do use the stock dx harness, and add the 4 wires.
here is some good literature
http://www.fourthgenhatch.com/
technical, info, mpfi swap
Old Jan 28, 2006 | 11:12 PM
civic889802's Avatar
Default Re: DPFI to MPFI (court)
i got resistor box for 20 bucks so if u need let me know
Old Jan 28, 2006 | 11:43 PM
Rywire's Avatar
Default Re: DPFI to MPFI (civic889802)
you cant use the si harness, trust me
Old Jan 29, 2006 | 12:09 AM
2kTeg's Avatar
Default Re: DPFI to MPFI (droppedcrxsi)
thanks, im just going to extrend the wires i need. I have a few extra harnesses from an HF laying around that im gonna use for a doner harness thanks for the help fellas
Old Jan 29, 2006 | 08:36 AM
highroller54's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">you cant use the si harness, trust me</TD></TR></TABLE>
listen to this man
tijuanavtec
Dec 22, 2009 03:02 PM
Red_ED8
Jun 19, 2007 01:42 AM
1 Fly SI
Nov 9, 2006 11:51 AM
HondaHeddie
27
Oct 6, 2006 07:57 PM
mobrep
Jan 5, 2004 05:31 AM
