98 USDM ITR Corner Weight
Today, I put my ITR on the four-wheel scales at my friend's shop. I was curious how well it was balanced with the Mugen Lowdown suspension. The setup is a 98 USDM ITR with full interior, Mugen Lowdowns and a half tank of gas. The car was very well balanced compared to other "stock" cars that I have seen on the four-wheel scales. Without me in the car, the car weighed 2,567-lb, Front Left - 801-lb, Front Right - 804-lb, Rear Left - 493-lb, Rear Right - 469-lb. I weigh about 205-lb. With me in the drivers seat the car weighs 2773-lb, Front Left - 871-lb, Front Right - 835-lb, Rear Left - 574-lb, Rear Right - 493-lb. I just thought this information might interest you guys.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98 Spec R »</TD></TR><TR><TD CLASS="quote">With me in the drivers seat the car weighs 2773-lb, Front Left - 871-lb, Front Right - 835-lb, Rear Left - 574-lb, Rear Right - 493-lb. I just thought this information might interest you guys.
Not bad, only off by about 45 lbs if I did my math right? With 400 in-lb springs, you are only off by a tenth of an inch on one corner.
What pressure were your tires? All even?
</TD></TR></TABLE>Not bad, only off by about 45 lbs if I did my math right? With 400 in-lb springs, you are only off by a tenth of an inch on one corner.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F »</TD></TR><TR><TD CLASS="quote">
What pressure were your tires? All even? </TD></TR></TABLE>
My tire pressure was 35 psi all the way around. I am pleased with the results especially since I can't adjust the Mugen Lowdown suspension.
Im_In_There
Jul 19, 2004 02:01 PM
