cleaning lenses of headlight? diy
Old Jan 28, 2006 | 06:25 PM
rota power's Avatar
BANNED
Default cleaning lenses of headlight? diy
is there a way to polish up the insides of the headlights
there was a thread on how to clean up the scuffs on the inside lenses i believe with the eagle 1 polish. anyone have that link?
edit: i found the link to clearing scratches
also how do u take apart a headlights off an ej8 em1 etc. the cover from the housing. im afraid the plastic housing will break
Old Jan 28, 2006 | 07:06 PM
777's Avatar
777
Default Re: cleaning lenses of headlight? diy (namez)
I'd like to know too.......
Old Jan 28, 2006 | 07:44 PM
rota power's Avatar
BANNED
Default Re: cleaning lenses of headlight? diy (KILLA_EK9)
the 2 screws
Old Jan 29, 2006 | 12:30 PM
777's Avatar
777
anyone out there................
Old Jan 29, 2006 | 12:37 PM
777's Avatar
777
bump
Old Jan 29, 2006 | 02:59 PM
jdmztrane's Avatar
Just curious how you got scratches on the inside of the headlight lens cuz theyre sealed. As far as taking them apart.... just preheat an oven to 200 degrees, throw em in for 10 minutes and pull them apart. then there are two screws inside that connect the part that is chrome. Take those out and you should have 3 pieces (lens, housing, and the chrome piece). Do the same thing to put them back together but in reverse order.
As far as scratches, theyre probably on the outside. If theyre deep youre gonna have to work on wet sanding til theyre gone. Then get some Meguires Plastic X and clean them. Then put a nice coat of wax on em and your good to go.
Old Feb 8, 2006 | 06:07 PM
Squelch's Avatar
Default Re: cleaning lenses of headlight? diy (jdmztrane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmztrane &raquo;</TD></TR><TR><TD CLASS="quote">Just curious how you got scratches on the inside of the headlight lens cuz theyre sealed. As far as taking them apart.... just preheat an oven to 200 degrees, throw em in for 10 minutes and pull them apart. then there are two screws inside that connect the part that is chrome. Take those out and you should have 3 pieces (lens, housing, and the chrome piece). Do the same thing to put them back together but in reverse order.
As far as scratches, theyre probably on the outside. If theyre deep youre gonna have to work on wet sanding til theyre gone. Then get some Meguires Plastic X and clean them. Then put a nice coat of wax on em and your good to go. </TD></TR></TABLE>
what grit sandpaper to use??
Old Jun 17, 2006 | 06:02 PM
Bimmer99's Avatar
plastx doesn't seem to be working for me but i did locate a thread about how to do it
https://honda-tech.com/zerothread?id=813209 it's decent but the pics are gone but you get the hint
vodkaTM
Feb 5, 2009 01:55 PM
agati
Honda Civic (2001 - 2005)
Oct 28, 2008 01:06 PM
Roybal 3
Aug 18, 2008 12:37 PM
I Like Hondas
Jul 5, 2006 11:16 AM
CivicBoi
Jul 21, 2002 07:30 PM
