Apexi RSM wiring for GS/LS ecu
Today I pick up the new Apexi Rev/Speed meter and I am trying to find the right ECU wiring/socket diagram for my 2001 Integra GS, but none of the diagrams match what I have. I can only presume they only have the diagrams for ITR/VTEC ECUs. Have anyone installed this on a LS/GS integra??? Or Anyone have the right ECU wiring diagram for LS/GS ???? Thanks!
Well for one, the Ignition wire is not where it should be, as in the ecu outlet, there's no wire coming out of that pin.
For EXAMPLE: http://www.hyakushiki.com/reads/sfc-vtec/h4.html
(I know that's not the unit I am installing, but the diagram seem simlar to my socket layout). If you look at the Ignition Power pin, In my ECU there's no wire coming out of that, There are however wire coming out from the pin right beside it (left of it).
