car boggs at 3000 RPM
I did a b16A into my 90 CRX DX and it runs great... except when it gets around 3000 to 3500 rpm then it start to bogg alittle and then after that its fine any one have any ideas?
Idle Air Control Valve its on the back of the intake manifold, make sure its plugged in.. how does the car idle? did you have that code before the swap? if not, change the idle air control valve
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdeemseerx »</TD></TR><TR><TD CLASS="quote">Idle Air Control Valve its on the back of the intake manifold, make sure its plugged in.. how does the car idle? did you have that code before the swap? if not, change the idle air control valve</TD></TR></TABLE>
on a few swaps ive done, the iac trips out the first couple of min. usually when i turn the car off, run it, turn off, run it... it goes away
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotorcrx1987 »</TD></TR><TR><TD CLASS="quote">check the v-tec wiring harness if it boggs out at 3000 rpm or it might be a vacum problem</TD></TR></TABLE>
wtf is a vtec wiring harness?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pee Wee »</TD></TR><TR><TD CLASS="quote">mine did the same thing with a PW0. did an OBD 1 conversion and it was gone
and just incase you needed
https://honda-tech.com/zerothread?id=1510399
i just made that today : P
</TD></TR></TABLE>and just incase you needed
tdubbebawllin
Apr 20, 2009 08:05 PM
hondaZvic
Sep 8, 2007 09:14 AM
jonman27
Aug 17, 2006 11:31 AM
