what are the torque specs on d16z6 valves.
Old Jan 28, 2006 | 11:38 AM
95lscivic's Avatar
Default what are the torque specs on d16z6 valves.
i have two lose valves on my z6 and need to know the torque specs so i can adjust them. they make a slight ticking noise nothing serious but i need to adjust them because im selling the motor, and dont want to be ripping somebody off.
Old Jan 28, 2006 | 11:39 AM
91civicDXdude's Avatar
Default Re: what are the torque specs on d16z6 valves. (95lscivic)
it would be hard without some special tool (if they even make one) to torque down the valve lash adjusters and still hold the shaft with a screw driver. I usually just tighten then down as tight as i can get with a 12mm wrench
Old Jan 28, 2006 | 12:22 PM
95lscivic's Avatar
Default Re: what are the torque specs on d16z6 valves. (91civicDXdude)
thanx man that helps a lot. ill get on that, easy enough. does it eleviate the slight ticking for the time being for you?
mxmobbs
Sep 21, 2017 09:37 AM
salaamq
Dec 27, 2011 07:33 PM
vinuneuro
Apr 15, 2007 01:51 PM
iphatcrxi
Dec 9, 2004 06:39 PM
