Spoon head gasket for H22a, worth the investment?
Old Mar 23, 2002 | 05:36 PM
se93's Avatar
Default Spoon head gasket for H22a, worth the investment?
A friend of mine is going to tear down his prelude vtec and wanted to know if the Spoonsports headgasket is a worthwhile investment. How much more compression does it provide? How much more torque needs to be applied to the head bolts considering it is a thinner gasket? Has anyone installed it on this board?
Thanks in advance.
Mark
Old Mar 24, 2002 | 06:17 AM
4bidden's Avatar
Default Re: Spoon head gasket for H22a, worth the investment? (se93)
id like to know what you guys have to say about this also. and how much are they running?
Old Mar 24, 2002 | 06:31 AM
se93's Avatar
Default Re: Spoon head gasket for H22a, worth the investment? (4bidden)
Anyone on this board using the Spoon head gasket?
Any feedback will be appreciated.
Thanks,
Mark
Old Mar 25, 2002 | 03:26 AM
98Luder's Avatar
it is a 2ply headgasket
and I believe the compression gets bumped up .2 , so if your at 10:1 now, your compression goes to 10.2:1
I believe the cost is about 100~110US
I decided to go with a OEM headgasket myself, and I believe that the torque is 71~72lbs/ft for the head bolts. I don't see why you'd wnat to devate from that?
You can look at this two ways.....
1) every bit helps and if your running 11:1, 11.2:1 isn't too bad for 100bucks
2) this will throw some timing off, because the head gasket is thinner yea head will be closer to the block and cam sprockets may not align perfectly(but adjustable cam sprockets should fix that).
Personally I decided against it but that was just my personal choice I guess. If you head is off....might be a good idea to try it?
HiChanDC2R
Aug 31, 2010 08:28 AM
VSBB6
Sep 27, 2004 07:54 AM
GranPrix
May 28, 2003 01:24 PM
Vtec GSR95
Oct 28, 2002 05:49 PM
2.2
May 28, 2001 09:15 AM
