quick blinker light?
Old Jan 28, 2006 | 08:56 AM
egzo04's Avatar
Default quick blinker light?
how do u make your blinker light flash quicker? i need this accord infront of me that did it, i think its some kind of lightbulb or something?
and im not talkin about when one of your lights goes out and it goes all crazy
Old Jan 28, 2006 | 09:05 AM
P_Adams's Avatar
Default Re: quick blinker light? (egzo04)
Probably installed LED's w/out the corresponding resistors in some of the directional bulb sockets.
P
Old Jan 28, 2006 | 09:14 AM
Ross 2.0's Avatar
In a Junkyard near you.
Default Re: quick blinker light? (P_Adams)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams &raquo;</TD></TR><TR><TD CLASS="quote">Probably installed LED's w/out the corresponding resistors in some of the directional bulb sockets.
P</TD></TR></TABLE>
That's what i've been looking for. Please elaborate.
Old Jan 28, 2006 | 09:21 AM
P_Adams's Avatar
Default Re: quick blinker light? (MooGoCow3)
If you insist.
LED's by their nature, do not exhibit the same internal resistance for the same voltage rating, and because of this, an LED rated to replace (say) an 7440 bulb (or 1156) would require a resistor wired in series with it as to show the same total circuit resistance the flasher unit is expecting. For example, an LED (without the resistor) being of a lower internal resistance would act more and more like a bulb that had shorted across the filament, flashing faster....
P
Old Jan 28, 2006 | 09:53 AM
Ross 2.0's Avatar
the reason I asked was I want to put LED 1157's and when the bulb is locked in they don't work. I've settled myself to wait till the technology evolves. I'm not talking about turn signals I mean brake lights. If I put the bulb in backwards it seemed to light propperly but of course I couldn't lock it in. Probably just poor design... What OHM resistor should I use if anybody ever makes a bulb that will work propperly?
Should have known to ask you in the first place. Thanks!
Old Jan 28, 2006 | 12:19 PM
P_Adams's Avatar
The second Funky thing about LED's (Light Emitting Diodes) is, just like all Diodes; they are directional. You can hook them up just one way. This isn't much of a consideration for bulbs like 7440's and 1156's, but when you take 1157's and 7443's - they are directional (and if they're manufactured backwards, you can't just flip them around)
P
Old Jan 28, 2006 | 01:14 PM
BLKFLSH's Avatar
Just something I thought of when reading. If you can't turn the bulb around (won't lock), could you switch the wires on the plug to make it work right?
Old Jan 28, 2006 | 01:43 PM
P_Adams's Avatar
Default Re: quick blinker light? (BLKFLSH)
Old Jan 28, 2006 | 01:48 PM
Ross 2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLKFLSH &raquo;</TD></TR><TR><TD CLASS="quote">Just something I thought of when reading. If you can't turn the bulb around (won't lock), could you switch the wires on the plug to make it work right?</TD></TR></TABLE>
i considered that BUT when the bulb is locked in the right direction it won't work. When i just hold it in there without it locking the light will turn on but as soon as it locks in it's off again, brake and running light. So i'm just sticking with the old fashioned bulbs untill someone designs an LED bulb with LED's facing outwards and to the side, with an internal resistor. It shouldn't be too far off... i hope.
Old Jan 28, 2006 | 08:16 PM
cd5_2NR's Avatar
another way to do it..is with a potentiometer...do a search on google and you'll find a step by step on how to do it..
it'll actually make your blinker speed adjustable...it'll cost about 2.50 to do the mod...but be warned...many HTers hate fast blinkers...
lol...
Old Jan 28, 2006 | 11:05 PM
92ehatch's Avatar
Default Re: quick blinker light? (cd_5TUNR)
i hate quick blinkers because lights, of any color at night tend to be bright to me.
nothing i hate more than going home after a long tiring day at work and having to watch a strobe light
bopbop93030
Aug 4, 2008 02:40 AM
honda genome
Dec 14, 2006 05:41 PM
CdTriX
Jan 1, 2005 09:33 PM
shrekz
Apr 13, 2004 07:46 PM
niteboyzzz
May 12, 2003 01:49 PM
