what pistons on a h23 vtec
Old Jan 27, 2006 | 08:20 PM
roycivic92's Avatar
Default what pistons on a h23 vtec
what are the best choises u guys have, a buddy tells me to put type-s but wont that raise the comp too high. I need something relaible but dont want to leave the h23 pistons in the block. any body have a idea whats the comp with h23 piston h22a/type-s.
Old Jan 27, 2006 | 08:48 PM
hu's Avatar
hu
Default Re: what pistons on a h23 vtec (roycivic92)
If you put h22 pistons in a h23 block, the h22 piston will stick out of the block. Just get h23 spec. pistons. You can go with Wiseco or CP. Others probably make h23 pistons, I don't know for sure.
Old Jan 27, 2006 | 10:01 PM
TheWalrus's Avatar
Default Re: what pistons on a h23 vtec (hu)
what? they stick out of the block like how far? im considering this build and all i heard was they give you 12.5:1 cr or so
Old Jan 27, 2006 | 10:04 PM
hu's Avatar
hu
Default Re: what pistons on a h23 vtec (weenie)
There was a recent thread about it. I didn't even know until I read the thread. They will stick out .020. Clay the engine to make sure it is okay. The H22 pistons are taller than the h23 pistons.
Old Jan 28, 2006 | 02:52 PM
H23vtecEG's Avatar
i had type-s pistons in h23vtec. i was fine, no problems
Old Jan 28, 2006 | 03:48 PM
LudeyKrus's Avatar
Default Re: what pistons on a h23 vtec (H23vtecEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H23vtecEG &raquo;</TD></TR><TR><TD CLASS="quote">i had type-s pistons in h23vtec. i was fine, no problems</TD></TR></TABLE>
LIAR ! ! ! !
H23 VTEC w/....
H23 pistons: 9.3:1
USDM H22 pistons: 11.1:1
JDM H22 pistons: 11.6:1
Type-S H22 pistons: 12.3:1
IIRC, those are pretty damn close numbers.
Old Jan 28, 2006 | 07:50 PM
ralpheezy's Avatar
Default Re: what pistons on a h23 vtec (LudeyKrus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">LIAR ! ! ! !
H23 VTEC w/....
H23 pistons: 9.3:1
IIRC, those are pretty damn close numbers. </TD></TR></TABLE>
What would those numbers be if the engine had an F23 crankshaft (97mm stroke)?
Old Jan 28, 2006 | 09:21 PM
b18c1civic95's Avatar
h23a or h23a#?? the actual vtec h23?? if your talking about the stock h23 vtec then yeah you can use type s thats what im running.
Projectludatic
Oct 7, 2010 10:38 PM
mightymaxgst
Jan 20, 2009 08:31 PM
Jdmprelude94
Apr 16, 2005 09:10 AM
flamingaccord
Dec 2, 2003 03:26 PM
