Golden Eagle Fuel Rail
Old Jan 27, 2006 | 07:58 PM
Prelude_2_NV's Avatar
Default Golden Eagle Fuel Rail
So my friends and I get around to installing my newly aquired Golden Eagle Fuel Rail. The piece is well engineered but just has design flaws to not make it a bolt on piece or a stock replacement. The chamber for the fuel is massive and will be able to fuel even the most fuel hungry turbo applications.
Now onto the problems:
1. The rail comes with a banjo fitting so you can make it a "bolt on". However, it protrudes horizontally causing interference with the EGR. To get around this, we made a blocking plate.
2. The next problem is the stock banjo fitting from the H22A. It has to make a harsh kick to be able to mount onto the new fuel rail. To fix this problem, we used a D-series fuel line as it has that bend to make it mountable.
3. The mounting brackets that mount it to the intake manifold is too short causing the rail to sit too low. This means the injector clips won't be able to clip onto the injectors. To alleviate this problem, we used D-series fuel rail spacers.
4. The middle 1/8 NPT ( pipe ) port could be used to mount the sensor for a fuel pressure gauge. However, it is in direct line with the IACV. So we had to plug that up using the supplied plug.
All in all, this fuel rail was a headache to install for a stock replacement. I purchased it so I would be able to hook up my fuel pressure gauge, but that didn't happen. Another reason I purchased it is because I'm getting parts that would be re-usable when I do my engine build up. So at the end of the day, my fuel pressure gauge is still not hooked up.
Old Jan 27, 2006 | 09:43 PM
Hawkze_2.3's Avatar
Default Re: Golden Eagle Fuel Rail (Prelude_2_NV)
Damn....the only problem I had with my AEM rail was me bending the fuel line by accident.
Old Jan 28, 2006 | 12:00 AM
Dr.Colossus's Avatar
Wow... that sounds like a pain to install! I was thinking about getting a GE rail, but now I don't know Was this for an H22 or 23?
Old Jan 28, 2006 | 02:37 AM
Default Re: Golden Eagle Fuel Rail (Dr.Colossus)
This was for an H22. Same fuel rail for both motors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">Damn....the only problem I had with my AEM rail was me bending the fuel line by accident. </TD></TR></TABLE>
I wish I went with the AEM rail instead.
ghostriderinnc
Jul 31, 2010 09:38 AM
johnwohl
Feb 10, 2008 11:07 AM
HpRevolution
May 23, 2007 09:42 AM
Boostage
Sep 30, 2004 04:20 PM
bluebullet
Jan 7, 2004 08:44 AM
