Is there a guide on how to replace a ignition switch on a 93 civic ex coupe?
I don't know about a guide. It's not that hard. Remove the black plastic housing that goes around the blinker, wiper stalks, and ignition. You will need a dremel to cut a slice in the top of the left over bolt heads that secure the ignition. Use a screw driver to remove the bolt. Disconnect all wires and it's out. Order new bolts or reuse the ones you cut and reinstall.
jdmsir4dr
Oct 1, 2011 02:31 PM
