92 civic radiator
i am buying for a suspension build. i have bought an innovate mounts front crossmember which alows the use of a 92 civic radiator and i was wondering what i would have to do to make it work, because the fan doesnt fit and i think they have different connectors for the 1/2 size civic radiator.
I know what you mean. I have the innovative front crossmember which has the mounts for an eg radiator. I put in a 99-00 si radiator and fan but it seems like the fitting it too tight. I will get a picture for you if you need. I upgraded to fit my bombass header that I am going to buy but I had to cut the fan shroud just to make room for my shitty dc headers. I don't know if its cause the si fan is bigger or if it's cause of the crossmember.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtechrex »</TD></TR><TR><TD CLASS="quote">i am buying for a suspension build. i have bought an innovate mounts front crossmember which alows the use of a 92 civic radiator and i was wondering what i would have to do to make it work, because the fan doesnt fit and i think they have different connectors for the 1/2 size civic radiator.</TD></TR></TABLE>
I have not done this but I would think the EG Civic fan would bolt right up and as far as the wires go, just repin them, not that hard. It just needs power and ground
