EGR block off!! SEARCHED - OBD2
i was thinking about blocking my egr valve. i heard it might throw a EGR flow code . true or not true. can I block it off with out any worries?
http://www.honda-performance.c...d=426
^ KMS sells them. Most people make theirs out of aluminum. Up to you. As far as a CEL, some people get one and some dont. You can always reset the CEL.
egr cel wont run in limp mode, i have block off on my 4th gen, i get a cel every now and then, usually between 35-60mph at a consistant cruise. i just pop start it and it goes away. im lookin for a way to get rid of the CEL. and have been unseccesful
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93h22a1vtec »</TD></TR><TR><TD CLASS="quote">egr cel wont run in limp mode, i have block off on my 4th gen, i get a cel every now and then, usually between 35-60mph at a consistant cruise. i just pop start it and it goes away. im lookin for a way to get rid of the CEL. and have been unseccesful</TD></TR></TABLE>
umm aren't your obd1 get a p72 or p28 don't have the egr function and chip it or hondata
This is why disabaling the EGR is stupid as it only injects exhaust gases under the conditions described above. Not at WOT. It's only worth doing if you are going to epoxy fill the holes in the manifold and report the runners. and the only point of doing that is to get maximum performance out of the engine and help to not disrupt the airflow.
