Where to buy K&N RU-2820?
Old Mar 23, 2002 | 03:27 PM
98GeeYes-Are's Avatar
Default Where to buy K&N RU-2820?
Most people say they bought it for $30-$35. Where's that at? The places i've looked are about $45 shipping included.
Old Mar 23, 2002 | 05:14 PM
au-gsr's Avatar
Default Re: Where to buy K&N RU-2820? (98GeeYes-Are)
summit racing 800 230 3030
5 bux for shipping and its there in three days
i'd order the 3130 though. its the exact same size as the stock filter and can be modded to fit your intake just like the 2820
[Modified by au-gsr, 6:15 PM 3/23/2002]
Old Mar 23, 2002 | 07:23 PM
Calavera's Avatar
Default Re: Where to buy K&N RU-2820? (au-gsr)
They don't happen to have a website, do they?
Old Mar 23, 2002 | 08:20 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Isn't the 3130 smaller than stock, with a more conical shape? The 2820 is shaped exactly the same as stock, and is the same diameter as stock. If I didn't know it was universal I would swear it was meant to go in the stock airbox (after you attach it to the stock filter neck and the stock filter end cap). I highly recommend the 2820. My local AutoZone ordered it for me, $34.99 plus tax, picked it up 2 days later.
au-gsr's Avatar
Default Re: Where to buy K&N RU-2820? (Calavera)
you ever heard of google dot com? just kidding(i hate the people that say, "you ever try a search?"). yeah http://www.summitracing.com
if u use the 3130 you have to use the top piece of your old filter as well(the flat round plastic part with the little rubber gromet that holds the air filter in place closest to the front bumber). also try to reroute the tubing on the bottom of the intake box to somewhere where cold air can be drawn into the air filter box. good luck!!
Old Mar 23, 2002 | 08:23 PM
au-gsr's Avatar
yeah, sorry i get those two filters mixed up all the time.
Old Mar 23, 2002 | 11:12 PM
Thanks guys, I checked summit and they want about $45 shipped. Pepboys wanted $44.95. So I'm gonna check kragens and Autozone. Hopefully it'll be cheaper there.
Old Mar 24, 2002 | 12:37 PM
Community Builder
I used the top piece of the old filter on my 2820. It was exactly the right diameter. I just drilled 4 holes in the plastic piece and used 4 small (3/4" long) wood screws I think to attach it to the rubber K&N endcap. The screws went in easily into the rubber. It probably doesn't hold it very tight, but it doesn't have to.
Old Mar 24, 2002 | 02:35 PM
BSQ's Avatar
BSQ
Default Re: Where to buy K&N RU-2820? (PatrickGSR94)
You can get the RU-2820 at http://www.martelbros.com/cgi-bin/st...ore=direct.KNN for $35.99
Old Mar 24, 2002 | 02:45 PM
BSQ's Avatar
BSQ
Default Re: Where to buy K&N RU-2820? (BSQ)
Here is a comparision picture of the RU-2820 (left), RU-3130 (center) and stock filter (right).
Here are two pictures of the RU-2820 in the stock airbox.
Old Mar 24, 2002 | 02:59 PM
Westrock2000's Avatar
You just hacked the top off of the stock and accounted for the extra length when cutting the bottom off the K&N? Thats fits beautifully!
[Modified by Westrock2000, 5:59 PM 3/24/2002]
Old Mar 24, 2002 | 04:44 PM
pub's Avatar
pub
Default Re: Where to buy K&N RU-2820? (Westrock2000)
which part# fits into comptech's icebox?
Old Mar 24, 2002 | 04:57 PM
randomwalk101's Avatar
I have one for sale...it is used but in perfect working order. It is modified with the stock air filter to fit right into the stock airbox (ei. drop in). I will sell it to you for $20 if you're local. I'm kinda tired of shipping. I'm in Houston, TX
Old Mar 24, 2002 | 06:04 PM
BSQ's Avatar
BSQ
Yes, just remove the filter material from the stock filter elbow and attached the RU-2820. The RU-2820 is 0.5" shorter than the stock filter but this is made up by the mounting flange. Attached the white end cap and it looks just like the stock filter
no show no go
Oct 3, 2011 10:41 PM
SIK IN DA HED
Jun 2, 2004 12:08 PM
Jowee
Mar 9, 2004 11:52 PM
kkim
Apr 18, 2002 03:18 PM
Smokinsax
Mar 15, 2002 05:31 AM
