Skinnies, Let's talk skinnies tech
Old Jan 27, 2006 | 03:42 PM
TurboTegB18c's Avatar
Default Skinnies, Let's talk skinnies tech
I was wondering if there are any pros/cons to running differen't size skinnies, say a 22x3.5x15 vs. 24x3.5x15 or even a 26x4x15? Is it just a matter of looks, or just the smallest tire is the lightest tire? I have no clue. Maybe someone with more knowledge could chime in. Thanks, Paul
Old Jan 27, 2006 | 03:49 PM
B18c1turboedEK's Avatar
Default Re: Skinnies, Let's talk skinnies tech (TurboTegB18c)
Good topic!!!
Old Jan 27, 2006 | 04:00 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Skinnies, Let's talk skinnies tech (B18c1turboedEK)
Well a 15" rim will look better, and with a 24.0-15 x3.6 M&H we were able to get the right ride height we wanted. You want to go skinny. Plus, it is DOT and that is what you need for NHRA!
art
Old Jan 27, 2006 | 04:12 PM
Default Re: Skinnies, Let's talk skinnies tech (Arturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">Well a 15" rim will look better, and with a 24.0-15 x3.6 M&H we were able to get the right ride height we wanted. You want to go skinny. Plus, it is DOT and that is what you need for NHRA!
art</TD></TR></TABLE>
When u say the right ride height, are you referring to ride height for looks or for corner balancing? If so, how do we know that we are at the "right ride height".
We can turn this into a suspension tuning topic also
Old Jan 27, 2006 | 04:15 PM
Arturbo's Avatar
Better than steak
25 Year Member
I'll say this, when we corner balance our car we were just 3lbs off! chris is a bad ***.. No more info from me.
art
Turbo-charged's Avatar
skinnies chicks &gt; fat chicks
Old Jan 27, 2006 | 04:31 PM
Clayton's Avatar
H-T Administrator
25 Year Member
Default Re: Skinnies, Let's talk skinnies tech (Turbo-charged)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged &raquo;</TD></TR><TR><TD CLASS="quote">skinnies chicks &gt; fat chicks</TD></TR></TABLE>
BWAHAHAHAHAHA NOICE!
Old Jan 27, 2006 | 04:33 PM
yamuka's Avatar
even at max height, sometimes u cant get the proper ride height/corner weight u need, so going to a bigger skinny (24.5 vs 22) will give u more to work with
Old Jan 27, 2006 | 05:04 PM
ALLMOTOR18's Avatar
Default Re: Skinnies, Let's talk skinnies tech (yamuka)
wouldnt running a smaller diameter tire also help in lauching since there is less tire flex?.
Old Jan 27, 2006 | 09:54 PM
dunkd's Avatar
you have seriously been in a pointless post rage lately
Old Jan 28, 2006 | 06:15 AM
hondaguyef's Avatar
For sure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALLMOTOR18 &raquo;</TD></TR><TR><TD CLASS="quote">wouldnt running a smaller diameter tire also help in lauching since there is less tire flex?. </TD></TR></TABLE>
Never though of that Maybe John from M&H will chime in w/ some insight? Good point though^^
Old Jan 28, 2006 | 06:59 AM
SlicksMH's Avatar
Default Re: Skinnies, Let's talk skinnies tech (hondaguyef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef &raquo;</TD></TR><TR><TD CLASS="quote">
For sure
Never though of that Maybe John from M&H will chime in w/ some insight? Good point though^^ </TD></TR></TABLE>
You racers are doing find very good points.
John@M&H
Old Jan 28, 2006 | 12:40 PM
boostedcivicsir's Avatar
Mr. Badwrench
subscribing. ordering fronts and rears next week. john, you will be hearing from me!
Old Jan 29, 2006 | 01:28 AM
Fitti's Avatar
so size does matter
Old Jan 29, 2006 | 07:07 AM
SlicksMH's Avatar
Default Re: Skinnies, Let's talk skinnies tech (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">subscribing. ordering fronts and rears next week. john, you will be hearing from me!</TD></TR></TABLE>
John@M&H
Old Jan 29, 2006 | 05:48 PM
DEMNTD1's Avatar
Default Re: Skinnies, Let's talk skinnies tech (SlicksMH)
Would like to know more as well.
I got 22" slick on 13x8 Bogarts with 24" rear skinnies on 15x3.5 skinnies.
Ordering a set of 23" M&H slicks to test out since upgrading to 1.8L, but was thinking of resizing the rear skinnies to 22". Ride height is set to clear 24" rear skinnies from rubbing rear fender well. Was planning to resize rear skinnies to 22" to be able to lower vehicle a bit more.
slow_ls
Dec 15, 2006 08:42 PM
$amGD3
Jul 5, 2006 02:01 PM
carolinahondaboy
Sep 27, 2005 07:41 AM
Lil Corb
Apr 21, 2005 07:32 PM
Nader_D
Sep 17, 2003 03:29 PM
