Do Toda A/Skunk2 stage 1 cams make power til 9000?
I did a search and i remember Vegeta posted dynos of toda A awhile back ago but i can't find it anywhere. I'm wondering because if they don't make power to 9000 rpm, then i can just keep my valve springs and shift at stock redline.
In my experiance the Dont make power up there, but I dont think that it completly fall out either. SGT has made 210whp with Spec A's you should ask him
Guest
Posts: n/a
The powerband not only depends on cams, but your R/S ratio.
I have dyno'd a B16A with a stock bottom end, with type-R cams, that peaked at 9300 RPM and made power to over 10k.
With toda spec A's it would peak at about 9800.
Jeff
Jeff
Wow, SGT made 210 with spec As?? How about torque? OT but is it possible to hit 200whp without p/p the head?
Sorry this may be a stupid question, but what is R/S Ratio? Me thinks i should invest the extra 80 dollars for portflow inners...
Does compression ratio have any play into peak power? Or does it just give more power throughout the whole power band? I'm gonna be having a 11.5:01 compression.
Jeff
Jeff
19
Oct 14, 2004 04:57 PM
