Arghh!! Which belt goes where? (Putting together my motor)
Old Mar 23, 2002 | 02:24 PM
shamoo's Avatar
Will you make something up for me please?
Default Arghh!! Which belt goes where? (Putting together my motor)
I need some quick help here guys.
I'm finally assembling my motor and dropping it in. However, I don't know where the last three belts go!!!
I have the alternator, power steering, and A/C belt. These are the sizes:
4PK 790
4PK 920
4PK 870
If I put one on...the other two don't fit. It's so frustrating.
Which ones go where?
EDIT: I know I could just try all the combinations, but with my limited tool set and the cramped space, it takes almost 20-30 minutes to get at the belts alone!
[Modified by shamoo, 6:25 PM 3/23/2002]
Old Mar 23, 2002 | 02:36 PM
IMPATIENT's Avatar
Default Re: Arghh!! Which belt goes where? (shamoo)
well, at least you bought belts from honda, here you go....
4pk 920-power steering
4pk 790-alternator belt
4pk 870-waterpump, a/c
[Modified by IMPATIENT, 11:37 PM 3/23/2002]
[Modified by IMPATIENT, 11:38 PM 3/23/2002]
Old Mar 23, 2002 | 02:54 PM
shamoo's Avatar
Default Re: Arghh!! Which belt goes where? (IMPATIENT)
Thank you so much!
But right now as I have it, the 790 is on the alternator. But for some reason I can't stretch either of the others onto the "tensioner" for the AC/waterpump.
Am I missing something here? The tensioner thing is all the way slacked and down and the belt still won't fit onto it. It's too tight.
Old Mar 23, 2002 | 03:30 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
The waterpump is run by the timing belt. Are you sure you have the A/C idler pulley adjuster bolt loosened all the way?
[Modified by PatrickGSR94, 6:31 PM 3/23/2002]
Old Mar 24, 2002 | 11:01 AM
shamoo's Avatar
Default Re: Arghh!! Which belt goes where? (PatrickGSR94)
Alright....yeah you were right. One of the tensioners wasn't down all the way.
After a few frustrating hours, I got them all in! Thanks dude.
18psi is so close now!!!
Old Mar 26, 2002 | 10:00 AM
Rtzx9r's Avatar
GDD 1%
No offense
but why are you running 18psi if you are having trouble with belts???
Sounds like trouble to me.
Old Mar 26, 2002 | 11:13 PM
shamoo's Avatar
Default Re: Arghh!! Which belt goes where? (Rtzx9r)
No offense
Yeah yeah, I know.
But these belts are like so close, anyone can switch em around without noticing.
StraussBuster
Aug 22, 2013 05:59 AM
DC206R
Apr 16, 2009 05:39 PM
CALC!_JUST_du_IT!
Jun 10, 2008 12:55 PM
HondaH22a#1
Jun 29, 2007 08:27 AM
d8168055
Oct 5, 2002 06:59 PM
