newbie question... civic integra parts interchangable?
Old Jan 27, 2006 | 07:04 AM
bimmafrik's Avatar
Default newbie question... civic integra parts interchangable?
hey guys.. i just bought 1995 4 door gsr.. and i was looking around for some ground controls...
now the question is...
would a set that came off a 92-95 civic fit on my 95 4 door teg? any modification or simple bolt on..?
thanks guys in advance..
Old Jan 27, 2006 | 08:02 AM
M Coop's Avatar
Default Re: newbie question... civic integra parts interchangable? (bimmafrik)
I wouldn't try it, most likely won't make your car handle right, you have two different cars with different weights and spring rates, if it actually fits, I don't think it'll produce good handling results
Old Jan 27, 2006 | 10:12 AM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bimmafrik &raquo;</TD></TR><TR><TD CLASS="quote">hey guys.. i just bought 1995 4 door gsr.. and i was looking around for some ground controls...
thanks guys in advance..</TD></TR></TABLE>
The suspension is the same, between the cars, so if you have the same shocks as the donor (Ground Controls are sized for the shock they go on),then they'll work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M Coop &raquo;</TD></TR><TR><TD CLASS="quote">I wouldn't try it, most likely won't make your car handle right, you have two different cars with different weights and spring rates, if it actually fits, I don't think it'll produce good handling results</TD></TR></TABLE>
I wouldn't listen to this, unless you know more about them. The default rates for the Integra are fairly stiff, compared to stock, and even the Civic rates are going to be stiffer than stock, so they'll be an improvement. However, if they were originally ordered with custom rates, then you need to do some research and decide if those rates are what you want.
But don't do anything with stock shocks. You're going to lower the car and use stiffer springs, make sure you have shocks that can handle it.
Old Jan 27, 2006 | 06:27 PM
ernald711's Avatar
Default Re: newbie question... civic integra parts interchangable? (TunerN00b)
most parts do.
Old Jan 27, 2006 | 06:49 PM
numbnuts22715's Avatar
this thread is for civics, but its comparing integra parts to it, so it should help you out a bit...
https://honda-tech.com/zerothread?id=1024818
broketuner-Sol_Si
16
May 30, 2006 08:07 AM
96SR-V
Nov 28, 2005 10:09 AM
t0p_sh0tta
Audio / Security / Video
10
Mar 3, 2005 09:11 AM
john666
Jun 26, 2004 12:35 PM
Lei Siew Long
Feb 28, 2002 06:34 AM
