help! b18 swap into the dx...
Old Jan 26, 2006 | 09:24 PM
v8hnta's Avatar
Default help! b18 swap into the dx...
we dropped in a b18a into my dx and i took an si wire harness off another crx si i have here (same year mode 89), am i suppose to use the ls computer or could i just use the si computer of my crx si? for some reason it seem like my coil in my distributor is getting power but will not arc it through to create spark, what the hell am i doing wrong??? is the problem caused by the difference in computers, b/c all the other plugs went right in. any help is appreciated...
Old Jan 26, 2006 | 09:35 PM
31flavorscivic's Avatar
Default Re: help! b18 swap into the dx... (v8hnta)
1. You cannot use the SI harness. It simply will not work. You need to modify your existing DX harness.
Use the LS computer. I do however believe that it will start and somewhat run with the pm6 in it.
Get started on that and we'll go from there.
Old Jan 26, 2006 | 10:24 PM
Rywire's Avatar
Default Re: help! b18 swap into the dx... (31flavorscivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 31flavorscivic &raquo;</TD></TR><TR><TD CLASS="quote">1. You cannot use the SI harness. It simply will not work. You need to modify your existing DX harness.
Get started on that and we'll go from there.</TD></TR></TABLE>
Thats correct!
if you need wiring, let us know
Old Jan 27, 2006 | 05:20 AM
v8hnta's Avatar
thanks guys, i sent my wiring off to hasport just yesterday but i figured i would try that other one, guess not. will update soon with pics... LONG LIVE THE REX!!!!
IHEARTMYHONDA91
Mar 14, 2008 09:55 AM
hyperB16Turbo
Jul 1, 2005 12:29 PM
415Hatch
Jun 7, 2005 04:04 PM
P h i l
Feb 1, 2005 02:52 PM
bseriesboosted
Jan 29, 2004 12:55 PM
