WHAT TRANNY FITS A f23a1 ??
h22 and h23 tranny fit a f23a1 ? i have an automatic and these bitches are expensive! ...... i think it's going out.... i want a manual..... where could i get the peddles, linkage, all the stuff to do the swap? besides junkyard.... online? like made to do this...
please help me out
thanks!
please help me out
thanks!
did not get what u say... i understand they fit now.... but the rest of it did not sound right.....
what else would i have to have for the conversion..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cantaffordaccord »</TD></TR><TR><TD CLASS="quote">they fit as though they belong to the f23</TD></TR></TABLE>
oh really?
you can pretty much mount any sohc F series and H series on f23.
but please do beware the gear ratio and it's effect on powerband
oh really?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head »</TD></TR><TR><TD CLASS="quote">oh really?
but please do beware the gear ratio and it's effect on powerband</TD></TR></TABLE>
not totally true. you do not want a 90-91 accord transmission as they use a different tranyn case tht does not allow the 94-01 mounts from an accord to fit.
well i know that bronn and pkspx on http://www.honduh.com have both done the conversion pkspx had the h23 and bronn has the h22 the gears are noticably shorter and from what i hear acceleration is improved while gas milage is worse
but if you do the tranny swap id recommend swapping the 5th gear from the f23 over to the h22/23 so that you can drive on the hwy at a lower rpm that will help with gas milage
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cantaffordaccord »</TD></TR><TR><TD CLASS="quote">but if you do the tranny swap id recommend swapping the 5th gear from the f23 over to the h22/23 so that you can drive on the hwy at a lower rpm that will help with gas milage
Is that possible?? If so, that would be tha shizznit!
</TD></TR></TABLE>Is that possible?? If so, that would be tha shizznit!
i have heard that it works i with most interchangable trannys that honda makes i dont see why it wouldnt
id give it a try since you would have two trannys anyways
yep that's possible for sure. they're really the same transmission w/ different gearing so you can swap the gears between them. I haven't cracked into a honda transmission myself (yet) but have heard this from multiple sources.
ive tore a few F22 and H23 trannys apart before and the only thing i noticed was different, according to part numbers, was the actual final drive but i don't think i checked the fifth gear but i'm almost positive first and second are the same gear and that the final drive is where each gear seems to be shorter such as the F22 first and second go to close to 30 then 60 and the H23 tranny goes to just over 25 then around 55 with both trannys being on my F22b
