Speedo cable problem getting the core out of the tranny??? help???
Old Jan 26, 2006 | 06:52 PM
Markb16a's Avatar
Default Speedo cable problem getting the core out of the tranny??? help???
I have a b18c in my crx and I got a broken speedo cable and the core is broken off in the shafy how do I change that thing how do I get it out and replace that thing??
Old Jan 26, 2006 | 07:30 PM
therealpoorboy's Avatar
Default Re: Speedo cable problem getting the core out of the tranny??? help??? (Markb16a)
there is 1 10mm bolt holding the speedo gear in the tranny. undo that, slide the speedo mec. out, bang upside down.
Old Jan 27, 2006 | 02:50 PM
Markb16a's Avatar
koool thanks I will have to try that. someone else told me that too.
Old Jan 27, 2006 | 06:21 PM
wilwok's Avatar
i have a problem with my speedometer too, not working. opened the cluster up, undid all the plugs and took it for a drive. it seems the cable isn't turning. is it suppose to be turning? i think that's how the speedometer works right? can it be broken?
then i tried to take the thing out of the tranny. took off the 10mm but the thing wouldn't come out? what's a good way? i've tried pulling it and it still won't budge. sure it's just going to pop out or is there something else i missed?
Old Jan 27, 2006 | 06:33 PM
getnasty's Avatar
Default Re: Speedo cable problem getting the core out of the tranny??? help??? (therealpoorboy)
im getting ready to put a hydro trans in my crx.. waht do I do about the spedo?
Old Jan 27, 2006 | 06:54 PM
Rex18c's Avatar
Default Re: Speedo cable problem getting the core out of the tranny??? help??? (Kaotic Kustoms)
Just twist/tilt the speed gear left and right while pulling it out will do the trick. As for Kaotic Kustom, it depends on what gauge cluster you are using. If stock cluster then use the stock speedo cable and gear, everything will bolt up. If using 92-up cluster then you will have to get a vss from any 92-up civic or integra (would prefer the cx or so models with smaller vss, fits better) and wire it up. Hope this helps. I have a jdm gsr into my 91 crx si and I'm using a 98 Gsr cluster with a 93 civic vss.
marauder228vw
Dec 21, 2011 11:57 AM
theycallmepok
May 29, 2007 08:05 PM
Digitalcivic
Dec 24, 2002 08:54 AM
rasta420
Jul 7, 2002 07:50 PM
