Running CEL 21, on a non-vtec DOHC ZC???
i'm looking up codes, and from what i gather its a vtec code which is not possible, seeing as my ZC is non-vtec. and the second thing i come up with is Spool Solenoid Valve? looks like its connected to the distributor? anyone know if i should be worried....no one i talk to knows what the hell it does.
-thanx
-thanx
a spool solenoid valve is the "vtec solenoid valve" i refer to it as a midgets boner.. its located at the left hand said of the valve cover one wire coming out of it and 3 10mm around it like ^^^ is suggesting, your probably running the wrong ecu
ewing86
27
May 11, 2004 09:29 AM
