h23 cams
Old Jan 26, 2006 | 06:33 PM
phoshizzle88's Avatar
Default h23 cams
anyone know where i can find a good set of cams for an h23
Old Jan 26, 2006 | 07:26 PM
CivicSiDriver02's Avatar
Default Re: h23 cams (phoshizzle88)
Crower makes a set for the h23. I haven't had any personal experience with crower but they should be very high quality peices. You could also look into getting custom regrinds from a reputable shop.
Old Jan 26, 2006 | 08:02 PM
Pullig's Avatar
Default Re: h23 cams (CivicSiDriver02)
i have delta cam regrinds 272 duration .371 lift nice mid to upper power but have to upgrade springs and retainers. Retainers are smackin the valve stem seals. By the way u send in your stock cams and it cost 91.00 per cam.
Old Jan 26, 2006 | 08:26 PM
Default Re: h23 cams (Pullig)
how much does it cost to upgrade the vavle train
Old Jan 26, 2006 | 08:36 PM
Pullig's Avatar
im going with rocket motorsports 165 for the springs then 130 for the titanium retainers....
Old Jan 26, 2006 | 08:43 PM
gotta link to where i can get that
Old Jan 26, 2006 | 08:49 PM
do h22 cams work with h23
Old Jan 26, 2006 | 08:52 PM
Pullig's Avatar
http://www.kteller.com and no the cams are totally different vtec has more lobes
Old Jan 26, 2006 | 09:03 PM
whats your set up to get you to 14s
Old Jan 26, 2006 | 09:11 PM
Pullig's Avatar
well i ran this last year in feb. at night around 30- 40 degrees outside umm i had 17 inch wheels 215-40 tires umm 6 puck extreme clutch ebay short ram . 4-2-1 header no cat , no resonator , high flow muffler, underdrive crank and power steering and alternator, advanced timing on the distributor, ported throttle body a little bit not sure if it helped out too much or not,, o and i bypassed the coolant that goes thru the throttle body so it doesnt heat it. I have a SAFC tuned by me i just pulled some fuel where it was running really rich.
i now have motor mount inserts , 11lbs flywheel, and about to have my cams put back in so i cant wait to see wut times i can run
Old Jan 26, 2006 | 09:17 PM
what exactly does the safc do
Old Jan 26, 2006 | 09:21 PM
Pullig's Avatar
it richens or leans out the fuel
Old Jan 27, 2006 | 02:13 AM
PreLuDeSiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pullig &raquo;</TD></TR><TR><TD CLASS="quote"> i now have motor mount inserts , 11lbs flywheel, and about to have my cams put back in so i cant wait to see wut times i can run</TD></TR></TABLE>
did your motor mount inserts help alot with your wheel hop and how bad was the increase in vibrations from the engine?
Old Jan 27, 2006 | 08:47 AM
Pullig's Avatar
Default Re: h23 cams (PreLuDeSiR)
yeha it completely eliminated my wheel hop issue and yeah there is alot more vibration inside the car but u get used to it and it seems to not be so bad after a few months i guess it breaks in and all but its all good .
Old Jan 27, 2006 | 08:51 AM
PrecisionH23a's Avatar
use the cam thread in the FAQ
Old Jul 1, 2021 | 06:54 PM
Shawnaldson's Avatar
do you remember what springs and retainers you used on this. I've got stock springs
LUDEcidDream
Jan 28, 2011 07:51 PM
Dabrybry
Oct 21, 2008 02:21 PM
chitown2769
Oct 1, 2004 04:53 PM
ludeforce1
Feb 10, 2004 07:19 PM
