Timing Belt repl 90 Accord
Old Jan 26, 2006 | 06:18 PM
Edward44's Avatar
Default Timing Belt repl 90 Accord
Does anyone know a ballpark figure for replacing the timing belt on a '90 Accord? The repair place I usually take my car, a national chain, quotes about $800. A friend has told me that a friend of his who owns a garage will do it for $250. One one hand, I don't want to get ripped off by the major chain; but on the other I'm afraid that the independent is charging is so little because he might not do the best job. Anyone have any thoughts or advice?
Old Jan 26, 2006 | 06:53 PM
YeuEmMaiMai's Avatar
Default Re: Timing Belt repl 90 Accord (Edward44)
$400+ make sure they replace water pump drive belts balancer belts, etc
Old Jan 26, 2006 | 07:32 PM
P_Adams's Avatar
I'd be equally scared of both estimates. Depending on garage, I'd expect anywhere between $450.00 and $600.00 for an estimate which includes.
Camshaft timing belt
Counterbalance Drive Belt
Timing Belt Tensioner
Camshaft Front seal
Crankshaft Front Seal
Counterbalance shaft seal
Water Pump
---and the Associated Labor for Job.
I would accept no less extensive a job (I hate revisiting things)
P
Old Jan 28, 2006 | 09:23 AM
project93accord's Avatar
Default Re: Timing Belt repl 90 Accord (P_Adams)
Getting the entire T-belt job done for $253.42 but I know the mechanic....
Timing belt $32.85
Balancer belt $15.89
Power Steering belt $14.83
Air and Alt. belt $18.01
Water pump $34.97
Thermostat $6.87
Gallon of Anti-freeze $5.00
Labor is $125.00
am I missing anything that you guyz would recommend??
Old Jan 28, 2006 | 09:46 AM
amckee's Avatar
Default Re: Timing Belt repl 90 Accord (project93accord)
I would recomend that you buy Honda parts instead of what you have listed and pay your mechanic the $125 to install them. It's not a deal if the parts don't last.
Old Jan 28, 2006 | 12:00 PM
SteveoBA8's Avatar
Default Re: Timing Belt repl 90 Accord (amckee)
Yes go oem, way better quality.
Old Jan 28, 2006 | 12:09 PM
P_Adams's Avatar
This guys an angel if he's only charging you two hours labor. I would suggest that you discuss with him about a revised estimate based on the suggested parts list I suggested earlier.
If they haven't been addressed earlier, replace those 16 year old seals as well. Now is not the time to go cheap.
P
Old Jan 28, 2006 | 12:11 PM
Default Re: Timing Belt repl 90 Accord (SteveoBA8)
Thanks will do..
kc2mrg
Nov 10, 2010 09:05 AM
honda2112
Apr 15, 2010 05:10 AM
shepworldwide
Acura TL, RL & ZDX
Aug 15, 2006 07:37 AM
teler86
Jul 26, 2005 04:22 PM
