Battery light came on!
Old Mar 23, 2002 | 11:00 AM
CRexcellence's Avatar
New User
Default Battery light came on!
My Battery light came on in my rex. Its an 89 with a zc, I am thinking its the alternator...what do you all think?
Old Mar 23, 2002 | 11:45 AM
Rob!'s Avatar
Default Re: Battery light came on! (jrx2002)
i had the same problem with my crx too...it was my alternator but mine didnt start without a jump and from constant recharging the battery i went through brand newbattery. so my guess is its your aternator. buy a new one and put it in yourself...its very easy to do.
Old Mar 23, 2002 | 11:46 AM
whagkangmakulet's Avatar
mine was the alternator. To test it, start your car and disconnect your negative cable and see if it dies out! if it dies then it's the alternator
Old Mar 23, 2002 | 01:17 PM
Perfectionist's Avatar
Default Re: Battery light came on! (whagkangmakulet)
"". To test it, start your car and disconnect your negative cable and see if it dies out! if it dies then it's the alternator""
NEVER disconnect your battery on running vehicle. The battery performs a critical function in absorbing voltage transients that would destroy sensitive electronics.
Old Mar 23, 2002 | 02:53 PM
89 CRX SI's Avatar
Default Re: Battery light came on! (Perfectionist)
.true read that
[Modified by 89 CRX SI, 11:55 PM 3/23/2002]
Old Mar 23, 2002 | 07:16 PM
New User
Default Re: Battery light came on! (89 CRX SI)
ok so, i work for a honda dealer and they will check it out on monday, but i did go and try to start it up again tonight and it fired right up, and the light didnt come on... but to be safe some techs at work will check it..thanks for the replys
tyvtec23
10
Feb 10, 2012 11:22 AM
ef9one6
Apr 17, 2007 07:31 PM
smash fascism
Dec 22, 2005 09:13 PM
korean_teg
Sep 30, 2005 08:27 PM
c2etalon
Jun 13, 2003 05:19 PM
