Si Vs. LS
Old Jan 26, 2006 | 05:08 PM
143MYVTECEF's Avatar
Default Si Vs. LS
What is the difference between the LS caliper/rotor combo and the Si Caliper/rotor combo... I mean is one better than another and what would be the benifits of Ls brakes on a Civic Si
Old Jan 26, 2006 | 05:37 PM
EL Vap133's Avatar
Default Re: Si Vs. LS (143MYVTECEF)
If you mean 99-00 Si, then they are the same size as the Teg LS.
Old Jan 26, 2006 | 05:56 PM
.Grimace's Avatar
footwork mastery
Default Re: Si Vs. LS (EL Vap133)
and if you mean a 88-89 si then you would have rear disk brakes
Old Jan 26, 2006 | 06:07 PM
EL Vap133's Avatar
Default Re: Si Vs. LS (PurpleEKHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PurpleEKHatch &raquo;</TD></TR><TR><TD CLASS="quote">and if you mean a 88-89 si then you would have rear disk brakes </TD></TR></TABLE>
Wrong, only the 90-91 CRX Si had rear disc brakes.
Old Jan 26, 2006 | 06:14 PM
.Grimace's Avatar
footwork mastery
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">
Wrong, only the 90-91 CRX Si had rear disc brakes. </TD></TR></TABLE>
i meant if you had the 88-89 si the advantage of ls brakes would be rear disk
Old Jan 26, 2006 | 07:04 PM
Im refering to the front brakes of a 89 hondacivci Si Vs. 90-91 LS front brakes
Old Jan 26, 2006 | 07:10 PM
jccrxtuner916's Avatar
you will notice a improvement on braking IF you get the brake booster and cylinder from teh integra as well otherwise it will be a minor improvement... i have all 4 discs from a 93 LS... i didnt notice a big difference till i got the booster and cylinder from a 92 LS... u get some looks if you have all 4 discs...
Old Jan 26, 2006 | 07:25 PM
Default Re: (jccrxtuner916)
becasue i have both Ls spindles W/ Brakes and Si spindles W/brakes... So im curious if i should swap out spindles while im doing my B16 swap again
Old Jan 26, 2006 | 07:33 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 143MYVTECEF &raquo;</TD></TR><TR><TD CLASS="quote">Im refering to the front brakes of a 89 hondacivci Si Vs. 90-91 LS front brakes</TD></TR></TABLE>
In that case, the front Teg brakes are bigger than the 89 Si brakes. Just swap out the whole front brakes but use your stock upper arms.
rexfan
Mar 15, 2007 11:49 AM
Del Campo92
Mar 17, 2006 11:57 PM
JUN.
Jan 4, 2006 08:10 PM
puffine
15
Oct 16, 2005 05:51 PM
Dent Free
Nov 16, 2004 03:53 PM
