What size wrench/socket to take out 98 GSR knock sensor?
Old Jan 26, 2006 | 01:14 PM
Charlie Moua's Avatar
Default What size wrench/socket to take out 98 GSR knock sensor?
I'm kind of puzzeled on how to go about taking out the knock sensor. It's kind of in a tight spot right above the coolant line too.
Any one with tips?
Old Jan 26, 2006 | 05:41 PM
Andrew01's Avatar
Default Re: What size wrench/socket to take out 98 GSR knock sensor? (Charlie Moua)
That is kinda tough. If you come in from underneath like changing your oil, you will need a deep well 27mm socket with a 3" extension to get it. Just gently push down on the hoses and get it in there. Now if you have oil cooler it is a bit tighter but can be done. Hope this helps.
Old Jan 26, 2006 | 07:16 PM
Dartanian's Avatar
Default Re: What size wrench/socket to take out 98 GSR knock sensor? (Andrew01)
Are you sure it is 27mm? I could have sworn it was smaller like 24mm, but it has been a while since I changed mine, so I can't remember.
I know I couldn't get a breaker bar up there, so I used a socket wrench. It should only be torqued to 40 ft/lbs.
Old Jan 27, 2006 | 08:42 PM
thanks fellas.... FYI it was 27mm
Modified by Charlie Moua at 3:58 PM 1/28/2006
Dogginator
Jul 10, 2006 08:45 AM
troubledtech
Mar 16, 2005 07:46 PM
integramic
Sep 15, 2004 05:52 AM
SiR831
Dec 25, 2003 11:01 PM
DubbleD
May 29, 2003 12:12 PM
