Rpms fluctuate going from 5th --> Neutral
Old Mar 23, 2002 | 09:44 AM
Toda Party's Avatar
Default Rpms fluctuate going from 5th --> Neutral
I just want to see if anyone else had/has this problem , or perhaps knows what's wrong...
If I drive on the highway for an extended period of time, and then i drop out of 5th into neutral to cost into a rest stop or whatever....the rpms go nuts!
4,500 rpm in 5th
-neutral-
1,100
2,000
1,500
800
2,000 (stays here for about 15 seconds)
then a normal idle @ around 1,100
anyone know why?
Old Mar 23, 2002 | 09:51 AM
B2FiNiTY's Avatar
Default Re: Rpms fluctuate going from 5th --> Neutral (Toda Party)
Rich, lean, rich, lean, rich,lean?
Old Mar 23, 2002 | 09:57 AM
FusionITR's Avatar
do u have a afc?
Old Mar 23, 2002 | 11:22 AM
Toda Party's Avatar
Default Re: Rpms fluctuate going from 5th --> Neutral (FusionITR)
i have no afc or anything like that.
Old Mar 23, 2002 | 11:49 AM
Floyd's Avatar
How long is it staying at those different RPMs?
When I am cruising in 5th, then stop for a light, the car idles high (I'm not sure exactly what RPM) for about 3 seconds, then drops to normal idle.
Old Mar 23, 2002 | 12:01 PM
Dropspeed's Avatar
Default Re: Rpms fluctuate going from 5th --> Neutral (Floyd)
I'd assume that dropping the rpms is alot for the IAC (idle air contol) valve to handle and it is just adjusting slowly. If the car has higher milage it might be worth the time to remove it and clean it with some carb cleaner.
Mattj
Old Mar 23, 2002 | 04:28 PM
smerk's Avatar
New User
Does this happen when your car is first warmed up or only after extended drives?
I've had the same problem but mine happened right when my car when warmed up. I adjusted the throttle screw on the throttle body and problem was gone. You have to chip off the seal to adjust it though.
Old Mar 23, 2002 | 07:54 PM
Floyd's Avatar
Default Re: Rpms fluctuate going from 5th --> Neutral (smerk)
Okay, I just got back from a friends house and was paying attention to the RPMs when I came to a stop.
-Clutch in, engine drops to 1500 rpm. As long as the car is moving the revs won't drop below 1500.
-A few seconds after the car rolls to a complete stop, the revs drop to 1100 rpm.
-A few seconds after that, the revs drop to 800 rpm where it will idle all day, unless the A/C unit kicks in.
What yours is doing sounds quite weird.
Old Mar 24, 2002 | 06:15 AM
IN VTEC's Avatar
Throttle plate might be sticking a little. Pull the gas pedal back with your foot to see if it drops. Or, just clean the TB butterfly.
LudeNEzz
Jul 5, 2007 09:26 AM
e jay one
Dec 3, 2005 01:58 PM
Pilchard
Jun 8, 2004 04:30 AM
'99luder
Apr 28, 2004 10:36 PM
