Honda S2000 Honda S2000
Oil change.
Old Jan 26, 2006 | 11:23 AM
AP1's Avatar
AP1
Default Oil change.
Using Mobil 1, its my first change, I was suggested 5 and a half quarts of oil. Anyone back that up? I think that is a lil excessive. Much thanks
Old Jan 26, 2006 | 11:28 AM
S2K K1DD's Avatar
Default Re: Oil change. (mikeiswaydope)
i use 5 everytime
Old Jan 26, 2006 | 02:55 PM
AP1's Avatar
AP1
manual says 4.5-4.8 with filter
k thx
Old Jan 26, 2006 | 03:14 PM
Nishant's Avatar
Default Re: (mikeiswaydope)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeiswaydope &raquo;</TD></TR><TR><TD CLASS="quote">manual says 4.5-4.8 with filter
k thx</TD></TR></TABLE>
it says 5.1 quarts with filter for both AP1 and AP2
it says 5.9 quarts when doing full overhaul of engine (rebuild)
easiest way to get this right:
- emtpy out all oil
- replace filter, don't forget to put some oil on the seals of the filter
- pour in 5 quarts
- wait awhile
- check dipstick and find out how much more you need to reach the max marker
- fill up whats needed and recheck the dipstick
all done
Old Jan 26, 2006 | 03:25 PM
SuzukaBlueAP2's Avatar
Default Re: (Nishant)
work for me.
Old Jan 27, 2006 | 04:31 AM
batguano's Avatar
"it says 5.1 quarts with filter for both AP1 and AP2
- emtpy out all oil
- pour in 5 quarts
- wait awhile
all done "
I agree. Thats how I do it.
Old Jan 27, 2006 | 09:56 AM
Francesco's Avatar
Default Re: (batguano)
start with 5
Old Jan 27, 2006 | 10:21 AM
Mr. Projekt's Avatar
* B A N N E D *
It's 4.8 quarts for an oil change, 5.1 quarts for a complete overhaul (dry, newly assembled motor).
Old Jan 27, 2006 | 11:48 AM
natedoggs2k's Avatar
Default Re: Oil change. (Slideways2000)
I have always used 5.5 quarts for every oil change I did.
Old Jan 27, 2006 | 02:07 PM
batguano's Avatar
From these conflicting responses I am beginning to wonder if we are all talking about the S.
Old Jan 28, 2006 | 05:17 PM
-iLLuZioN-B18C1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by batguano &raquo;</TD></TR><TR><TD CLASS="quote">From these conflicting responses I am beginning to wonder if we are all talking about the S.</TD></TR></TABLE>
lol
the manual says engine oil change capacity (including filter)
5.1 us qt (4.8 l , 4.2 lmp qt)
Old Jan 28, 2006 | 06:05 PM
Nishant's Avatar
Default Re: Oil change. (natedoggs2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by natedoggs2k &raquo;</TD></TR><TR><TD CLASS="quote">I have always used 5.5 quarts for every oil change I did. </TD></TR></TABLE>
you are overfilling, thats bad
Old Jan 28, 2006 | 06:06 PM
Nishant's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slideways2000 &raquo;</TD></TR><TR><TD CLASS="quote">It's 4.8 quarts for an oil change, 5.1 quarts for a complete overhaul (dry, newly assembled motor).</TD></TR></TABLE>
you are wrong, go look in the helm's son
Old Jan 28, 2006 | 07:23 PM
* B A N N E D *
Default Re: Oil change. (Nishant)
Service Manual.
Old Jan 29, 2006 | 08:22 AM
2000S2000Mike's Avatar
Old Jan 29, 2006 | 08:29 AM
redronin22's Avatar
Fack. I put oil in checked the dip stick after warming the car up and at 5 qts it was still somewhat low. so i added a bit more like 1/2 qt to get it to the top line. If it is indeed too much then i will run the risk of the oil foaming correct? what other adverse things can happen? Should i drain all the oil out and pour in only 5 qts? Or can i kinda of tilt the jacks on one side and drain out a quart. =-(
Old Jan 29, 2006 | 08:40 AM
Nishant's Avatar
Default Re: Oil change. (redronin22)
if you check the oil and it is not over the max line of the dipstick, you are fine. if you are over then you may cause some foaming.
Old Jan 29, 2006 | 08:56 AM
AP1's Avatar
AP1
Yeah, I have the service manual as well. 4.8.
5.1 for a complete overhaul. 5 seems too much, my dipstick met the max bar with 4.8 just fine. I refuse to overfill.
Old Jan 29, 2006 | 09:08 AM
S2SLOW's Avatar
Just changed oil yeaterday it holds 5.5 just to read full on the dipstick!!!!
It doesnt matter what the hell the manual says just check the stick but it says 5.1!!!!
Old Jan 29, 2006 | 10:22 AM
tyrone's Avatar
Default Re: (s2slow)
i always just put 1 quart in...
Old Jan 29, 2006 | 12:59 PM
Nishant's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeiswaydope &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, I have the service manual as well. 4.8.
5.1 for a complete overhaul. 5 seems too much, my dipstick met the max bar with 4.8 just fine. I refuse to overfill.</TD></TR></TABLE>
what service manual do you guys have?
i have the oem one from honda
it says 5.1 quarts, 4.8 liters for an oil change which is what is also written in our owner's manuals
Old Jan 29, 2006 | 08:35 PM
p nut's Avatar
Here you go, goof-*****!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s2slow &raquo;</TD></TR><TR><TD CLASS="quote">Just changed oil yeaterday it holds 5.5 just to read full on the dipstick!!!!
It doesnt matter what the hell the manual says just check the stick but it says 5.1!!!!</TD></TR></TABLE>
Old Jan 30, 2006 | 03:30 AM
S2SLOW's Avatar
Default Re: (P Nut)
[QUOTE=P Nut]Here you go, goof-*****!
Thats what mine says but obviously its not always correct!!!!
Old Jan 30, 2006 | 06:08 AM
tyrone's Avatar
he so no where in there does it say it needs to be synthetic oil... some goof ball told me it has to be synthetic oil according to honda... but i guess it doesnt???
Old Jan 30, 2006 | 06:52 AM
jamesdean65's Avatar
mobil 1 should not be used until you have at least 10k mi on your car. I use 5.5 quarts(but I have a supercharger). so when I reach 12k I will switch to M1 oil. I belive it has something to do with breakin.
