swap wont start
Old Jan 26, 2006 | 11:04 AM
Turbo_Mike's Avatar
Default swap wont start
I just put a 2000 ls motor into my 92 vx, and following tom's right up, i used the obd2 engine harness and plugged it into my vx harness. There was a 4th vx plug that had no where to plug into the ls harness. I"M using an obd1 p75 ecu.
I'm getting spark and fuel, its turning over, but wont fire. Timing is on correctly, and compression is good, and no CELs. I still need a pcv valve and to figure out where the control box vacuum hoses go, but that should only affect idle, not start up.
If i was getting fuel and have been cranking it over as much as i have been, should the plugs be wet? I pull them out and they are dry, but i cant smell guess cause i have a realy bad cold and its like 27* outside.
All my grounds are good....what else should i look for??
Also...there is a long lead coming from my pos. terminal on the ls harness that looks like it SHOULD be a groudn wire, but certainly isnt. where should this wire go to? ( No its not the one for the starter) ITs long, thick, and has white sheathing.
Old Jan 26, 2006 | 12:39 PM
Turbo_Mike's Avatar
Default Re: swap wont start (MIKE JONES)
BTW, the car ran like a top 3 days ago...
Old Jan 26, 2006 | 04:18 PM
Turbo_Mike's Avatar
ttt
Old Jan 26, 2006 | 04:33 PM
ComptonsF1NEST's Avatar
grounds?
Old Jan 26, 2006 | 06:35 PM
Turbo_Mike's Avatar
Default Re: swap wont start (ComptonsF1NEST)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ComptonsF1NEST &raquo;</TD></TR><TR><TD CLASS="quote">grounds?</TD></TR></TABLE>
All my grounds are good, i'm getting spark and everything...
I tested out the injectors tonight, and they were seeing 12 volts to only one prong on the clip not both....then i grounded out the other prong to make the injectors 'click' and they didnt....?
Old Jan 27, 2006 | 04:16 AM
Turbo_Mike's Avatar
bmp
Old Jan 27, 2006 | 07:31 AM
Turbo_Mike's Avatar
I followed the procedure in the hsm and tested the injectors in and out , back and forth. everything checks out. now i'm wondering if its the feed line to the fuel rail, and if i installed it correctly?
Should the bolt/fitting coming out of the fuel rail have a hole going through it? or only on the end going straight in the fuel rail? Mine only goes straight in, with no holes going straight through, but i have a d series in the garage that has a hole going straight down trhough it where the fuel line bolts on.... Could i be using the wrong hose setup or something?
Old Jan 27, 2006 | 07:37 AM
LordAphotic's Avatar
are you really sure your getting a spark? have you tried cranking it with the sparkplugs out of the motor to see if they really do spark?
and if they do spark. then take out hte fuel injectors and crank it ... it wil be obvious if they are shooting fuel. ....
and if your shooting fuel and its sparking and its cranking... then theres no reason it shouldnt be starting up. unless the pistons arent in the engine somehow..
Old Jan 27, 2006 | 09:53 AM
Turbo_Mike's Avatar
Default Re: (LordAphotic)
Yes spark is def there...
took out fuel rail and injectors and they are not squirting... all wiring checks out and is correct. injector resistance is perfect.... could all four be clogged from sitting????
Old Jan 27, 2006 | 10:18 AM
EJ8chu's Avatar
Default Re: (MIKE JONES)
take off your injectors and see if fuel come out then. if it does then its probally the injectors!
Old Jan 27, 2006 | 10:32 AM
Turbo_Mike's Avatar
Default Re: (xxsteve803xx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxsteve803xx &raquo;</TD></TR><TR><TD CLASS="quote">take off your injectors and see if fuel come out then. if it does then its probally the injectors! </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MIKE JONES &raquo;</TD></TR><TR><TD CLASS="quote">
took out fuel rail and injectors and they are NOT squirting... all wiring checks out and is correct. injector resistance is perfect.... could all four be clogged from sitting????
SO I NEED to know now if its 'probably' the injectors and i should buy another set, or if i could be overlooking something electrical like a ground???
Old Jan 27, 2006 | 01:43 PM
no it might not be the injectors... kinda weird that all 4 go out at the same time. it might be the fuel pump. make sure its turning on. make sure the fuse for the fuel pump isnt popped.
Old Jan 27, 2006 | 02:08 PM
SkankyEJ7's Avatar
cant you just use the ingectors out of your old motor, because correct me if im wrong but, arent most all of honda's OBD2 injectors 240cc's
Old Jan 27, 2006 | 08:17 PM
Turbo_Mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LordAphotic &raquo;</TD></TR><TR><TD CLASS="quote">no it might not be the injectors... kinda weird that all 4 go out at the same time. it might be the fuel pump. make sure its turning on. make sure the fuse for the fuel pump isnt popped.</TD></TR></TABLE>
yea thats what i thought, weird all four would not work...maybe one or two but not all four. Pump is def. turning on cause i have undid the fuel rail / line a few times and each time its pressurized with fuel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98ekhx &raquo;</TD></TR><TR><TD CLASS="quote">cant you just use the ingectors out of your old motor, because correct me if im wrong but, arent most all of honda's OBD2 injectors 240cc's</TD></TR></TABLE>
i sold the old motor, but those injectors were obd1 and i'm using an obd2 engine harness / motor...
Old Jan 28, 2006 | 10:19 AM
SkankyEJ7's Avatar
doh forgot about the my bad
Old Jan 28, 2006 | 01:13 PM
take off the fuel filter. and crank the car. fuel should come gushing out. just becareful when doing this.
if it is releasing fuel then move further down the line... its the fuel rail or the injectors... the fuel injectors are electronically controlled... so it might be that too.
Old Jan 28, 2006 | 03:14 PM
Turbo_Mike's Avatar
like i said, i pulled the rail and the injectors.... when i tried starting the car the injectors didnt spray, but they popped out from pressure in the rail
Old Jan 28, 2006 | 03:31 PM
hulk252's Avatar
sounds like you blew the injector driver in the ECU. try a new ECU
Old Jan 28, 2006 | 03:41 PM
Turbo_Mike's Avatar
Default Re: (hulk252)
yea i did, same result
Old Jan 28, 2006 | 03:45 PM
hulk252's Avatar
If you are gettin B+ at the injectors. check the injector wires at the ECU. See if you get a ground when you crank.
Old Jan 28, 2006 | 10:34 PM
I3ooS710's Avatar
Ignitor?
Old Jan 29, 2006 | 07:51 AM
Turbo_Mike's Avatar
Default Re: (I3ooS710)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I3ooS710 &raquo;</TD></TR><TR><TD CLASS="quote">Ignitor? </TD></TR></TABLE>
i have spark! lol
no fuel.. i dont think ignitor controls fuel ??
Old Jan 29, 2006 | 12:16 PM
i dont know what obd system your running... but are you running the same type of fuel injectors? like if your obd1 are you running obd1 injectors?
Old Jan 29, 2006 | 01:04 PM
Turbo_Mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hulk252 &raquo;</TD></TR><TR><TD CLASS="quote">If you are gettin B+ at the injectors. check the injector wires at the ECU. See if you get a ground when you crank.</TD></TR></TABLE>
what you mean b+ ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LordAphotic &raquo;</TD></TR><TR><TD CLASS="quote">i dont know what obd system your running... but are you running the same type of fuel injectors? like if your obd1 are you running obd1 injectors?</TD></TR></TABLE>
Well the car is obd1...i'm running an obd1 ls ecu, but the engine and engine harness are obd2. It is backwards interchangeable though so it plugs into an obd1 car and "should" work.
Old Jan 30, 2006 | 08:51 PM
Turbo_Mike's Avatar
help
