ecu or sensors?
i have a b20/b16 0bd0 with a pw0 ecu... ive been tryin to fix this problem for over 2 weeks now. it bogz really bad .. sometimes it bogs right when i start up and other times after a lil bit of driving. When i switch the 2 oxygen sensors around on my ecu (#1 oxy at c16 and #2 at c8), it wont bog unless im under like 3000 rpm.. gives me both #1 and #2 code. In the correct positions for the sensors, it gives me no codes but non stop bogging.. yu think its my ecu or sensors?
hopefuly this makes sense to some1.. thnz
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civichatchCrX »</TD></TR><TR><TD CLASS="quote">i have a b20/b16 0bd0 with a pw0 ecu... ive been tryin to fix this problem for over 2 weeks now. it bogz really bad .. sometimes it bogs right when i start up and other times after a lil bit of driving. When i switch the 2 oxygen sensors around on my ecu (#1 oxy at c16 and #2 at c8), it wont bog unless im under like 3000 rpm.. gives me both #1 and #2 code. In the correct positions for the sensors, it gives me no codes but non stop bogging.. yu think its my ecu or sensors?
you have a b20 block w/ b16 head on a pw0 (b16a) ecu? any tuning?
</TD></TR></TABLE>you have a b20 block w/ b16 head on a pw0 (b16a) ecu? any tuning?
covert to obd1 and get a chipped p28 for tuning or you could try to find some that tunes obd0 ecus, basicly your motor is 2 big for the fuel and timing maps of the b16 ecu.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89crxhf »</TD></TR><TR><TD CLASS="quote">covert to obd1 and get a chipped p28 for tuning or you could try to find some that tunes obd0 ecus, basicly your motor is 2 big for the fuel and timing maps of the b16 ecu. </TD></TR></TABLE>
That's what I was thinking, OBD 0 sucked IMO, all I have are ITR cams and my car would bog bad everytime Vtec tried to engage. converted to OBD 1 (JDM PR3 from XSi) and it has been awesome ever since, now I have problems with traction due to the power increase, OBD 1 ECU's where just sooooo much better stock ECU's than the OBD 0 were.
egcrazed
Mar 25, 2013 12:14 AM
