about getting turboedit
Old Jan 26, 2006 | 09:25 AM
kantfadedisazn's Avatar
Default about getting turboedit
does anybody know where i can get the turboedit software, and what do i need to run the software.
Old Jan 26, 2006 | 11:41 AM
31flavorscivic's Avatar
Default Re: about getting turboedit (kantfadedisazn)
from my exhaustive research done on http://www.google.com :
http://www.turboedit.org
lol j/p.
The software is fairly straightforward. You will need a rom burner, chipped ECU, and all that good stuff.
Let's start with, what is your application?
Old Jan 26, 2006 | 12:55 PM
Default Re: about getting turboedit (31flavorscivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 31flavorscivic &raquo;</TD></TR><TR><TD CLASS="quote">from my exhaustive research done on http://www.google.com :
lol j/p.
ohh thanks and ima running a pm6 ecu for a sohc zc swap
Old Jan 26, 2006 | 12:59 PM
To my knowledge what needs to be done is you get your program, then burn it to the chip using the rom burner you bought, then put the chip inside the ECU that you had a socket soldered into, and then you go and drive.
My friend did all of this last summer, but my memory of all of the steps to do this is kinda fading. It did work really well though. The launch control using the A/C button was cool.
Old Jan 26, 2006 | 01:41 PM
NCchris's Avatar
http://www.xenocron.com/info.php
HTH
chris
sfwdcrx
Dec 21, 2007 07:46 PM
vtec4max
May 10, 2007 09:59 PM
djSALIX
Jan 6, 2006 07:36 PM
senpai
Jun 13, 2004 04:39 PM
H22ACiViC
Feb 28, 2002 04:50 PM
