need help w/ check engine light
Old Jan 26, 2006 | 07:11 AM
luckypon7's Avatar
Default need help w/ check engine light
i have a 98 obd2 gsr, my problem is tha t it is throwing check engine light. once i clear it by unpluging the battery, what i notice is when i hold the gas paddle/throttle stady at one spot that is when it comes on...i can go days w/ out the light coming on if i fluctuate the throttle.. what can it be? hope you understand what i'm trying to explain...thank you in advance..
Old Jan 26, 2006 | 09:06 AM
s2kdre's Avatar
Default Re: need help w/ check engine light (luckypon7)
reseting the battery doesnt reset the ecu, it still stores history codes.
Old Jan 26, 2006 | 09:11 AM
BS 22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luckypon7 &raquo;</TD></TR><TR><TD CLASS="quote">i have a 98 obd2 gsr, my problem is tha t it is throwing check engine light. once i clear it by unpluging the battery, what i notice is when i hold the gas paddle/throttle stady at one spot that is when it comes on...i can go days w/ out the light coming on if i fluctuate the throttle.. what can it be? hope you understand what i'm trying to explain...thank you in advance.. </TD></TR></TABLE>
https://honda-tech.com/zerothread?id=978933
Old Jan 26, 2006 | 09:46 AM
sleeperteg's Avatar
Default Re: need help w/ check engine light (jdmhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda &raquo;</TD></TR><TR><TD CLASS="quote">reseting the battery doesnt reset the ecu, it still stores history codes.</TD></TR></TABLE>
i thought you could reset the ecu by unpluggin the negative battery cable for a few mins... how u reset the ecu so its not still throwing old codes.
Old Jan 30, 2006 | 05:19 AM
luckypon7's Avatar
Default Re: need help w/ check engine light (sleeperteg)
well i unplug the battery and cleared the code..wait like a day and went to take the emission test and pass... thanks to GOD.. well the check engine light stay off long enough to pass but it is now back on... if i am reading it correctly it's through this code..90 Evaporative Emission Control System leak detected in the fuel tank area .
how would i fix this?
sherman
Honda S2000
13
Jun 22, 2006 04:13 PM
kantfadedisazn
Feb 3, 2006 08:10 PM
B18CR-X
Mar 27, 2004 06:38 AM
Beast53568
Apr 12, 2003 10:14 PM
