help on a d16y7 swap on crx hf
i got a 91 crx hf in order to put a d16y7 engine in it do i have to put the si wiring harness in it or can i use the stock harness
Use the stock hf harness. Just eliminate the egr..
If you want to make this easy as possible use the hf distributor and intake manifold..also you may want to change the ecu as the stock on is for 1.5 8 valve motor,,,The pm6 would be better even though not the correct one..
peiku
Feb 21, 2006 03:10 PM
JSPECHB
Jul 16, 2003 07:31 AM
paulzy
Jun 21, 2003 03:34 AM
