zc harness please need help ASAP
Old Jan 25, 2006 | 08:02 PM
pec pec's Avatar
Default zc harness please need help ASAP
i was wondering if a zc sohc engine wire harness(obd0) will work ok with a stock 90 honda civic hathback i mean by plug in play wise n ready to go
thanks to everyone whos helped
Old Jan 25, 2006 | 08:04 PM
onepoint6i's Avatar
Default Re: zc harness please need help ASAP (ef9 562)
90 civic DX? Si?
If your running MPFI (Si)depending on the year of the harness...maybe yes maybe not....you gotta check that the end plugs are the same..if they plug in then yes it will work...
Old Jan 25, 2006 | 09:43 PM
Rywire's Avatar
Default Re: zc harness please need help ASAP (onepoint6i)
if its zc, its rhd, so no
Old Jan 26, 2006 | 06:49 AM
jlicrx's Avatar
Default Re: zc harness please need help ASAP (droppedcrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">if its zc, its rhd, so no</TD></TR></TABLE>
OBD0 ZCs have same engine harness as 88 CRX/Civic Si, as far as connections to chassis harness (they are obviously different at the distributor on the DOHC) - OBD1 ZCs do have plugs for connecting to chassis harness reversed due to RHD, but not OBD0
Modified by jlicrx at 9:24 AM 1/26/2006
Lil ZC
14
Feb 11, 2011 12:27 AM
miggy23
15
Feb 20, 2010 07:47 AM
SC-MK1
May 22, 2005 08:51 PM
99sonicbluegsr
Sep 16, 2004 07:43 AM
DJ_SaNdOz
May 20, 2003 07:45 PM
